Counting time in Sec and save to EEPROM or FRAM
Hello,
I am using now days to figure out a simple way to count the time on an event. The event is starting and stopping. Will say every time the event is active count the time as long as it is active add it to the saved time and stop counting when the event is inactive. Writing every 5 minutes to save the EEPROM is enough.
I am using the Teensy 3.5 with onboard RTC.
This function is part of on Engine Gateway translating analog signals and engine states to a CAN bus like system.
WHat I tried until now was to set the start time using millis and the stop time using millis. subtract them to get the current running time. The event gets triggered as soon as the engine RPM is equal or above 200 RPM.
I think it is also no problem for me to get the time saved and read at startup from the flash device (eeprom or fram)
Is there a function of RTC which shows seconds elapsed since 1970? I thought I have read something like this somewhere, but I can“t find something similar in the docs.
Since the state of the engine can change several times while the teensy is powered up I run into problems. My programming knowledge is not yet very good, unfortunately.
Can you help me to get this function which starts when the event is given (RPM >= 200) and stopping counting as soon the engine is stopped (RPM<=200)?
The RPM counter I based on FreqMeasureMulti and working fine so far.
I thought to use simple if else to read the state of the engine. So the time counting function is missing.
There are a lot of running engine hour meters on the web, but all do not fit somehow or I do not understand them..
If you have not realised it already you need to act when the RPM becomes greater/equal to 200 not when it is greater/equal to 200 and similarly for the lower threshold. If you have not already coded the RPM speed detection this way then look at the StateChangeDetection example in the IDE
@UKHeliBob
the RPM stuff is already working as well the if rpm =<200.
That isn't the question.
What I need is the time counter!
Native does not have anything (I believe)
However there is library which was developed from the Arduino Playground time library.
It has a time_t timestamp (unix time), which can be set from an external source, and can be accessed at will.
autopilotNOR:
@UKHeliBob
That sounds right, but are you saving the millis() values when the limits become exceeded or when they are exceeded ?
Seeing your code would, of course, help considerably.
