counting time of running function.
This is my code for timing specific functions and displaying to LCD.
i chose float so it displays seconds with 2 decimal places. It gives me 7.02 seconds for function 1 and 3.07 seconds for function 2. i believe it to be accurate.
Can i improve upon this code? Do you see any problems with it?
unsigned char drinkSelection = 0;
  Serial.begin(9600);                       //Open Serial with baud rate 9600
  lcd.begin(0x27,16, 2);                    //Start lcd (address, rows, columns)
void adiosSucka()
    float oldMillis = millis();
    float time = 0;
  Serial.println("You have Chosen Adios Sucka");                    //Greetings
  Serial.println(" ");
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("You have chosen");
  lcd.setCursor(0,1);
  lcd.print("Adios Sucka");
  delay(250);
  yAxis->step(1050, BACKWARD, DOUBLE);delay(5000);
  time = millis() - oldMillis;
  drinkSelection=0;                                 //Reset Variables
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Drink made in");
  lcd.setCursor(0,1);
  lcd.print(time/1000);
  lcd.setCursor(2,1);
  lcd.print("seconds");
  delay(3000);
  lcd.clear();
  lcd.setCursor(1,0);                              //Restart Welcome
  lcd.print("Select a drink");
  time=0;
//(2) Alpine Lemonade [(30mL Vodka, Gin, Rum) (60mL Cranberry, Lemonade)]
void alpineLemonade()
    float time = 0;
  Serial.println("You have chosen Alpine Lemonade");
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("Alpine Lemonade");
  delay(3000);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.setCursor(2,1);
  delay(3000);
  lcd.clear();
  time=0;
Aaronkoe:
You could make it compile. (end of setup is missing, loop is missing)
You could/should move the measuring to the loop code, or even better to a function.
You should not use floats to hold unsigned long integer values (you only loose precision)
and you definitely should not use floats to hold millis or micros (because they wrap).
