counting void lop on testing rig
Hi
I need a timer to count actions on the serial monitor please.
The cod below is for testing rig for earth moving attachments product.
So, its open close 4 relay module in sequence which control hydraulic rams solenoid.
The test rig will run for few days but need to count how many void loop please?
I'd appreciate any advice you can give me.
Thanks
// initialize serial communication at 9600 bits per second:
pinMode(7, OUTPUT);
digitalWrite(7, LOW); // Turn the rellay on
delay(2000); // wait for 2 second
digitalWrite(7, HIGH); // turn the rellay off
delay(600);
pinMode(8, OUTPUT);
digitalWrite(8, LOW); // Turn the rellay on
digitalWrite(8, HIGH); // turn the rellay off
delay(600);
pinMode(9, OUTPUT);
digitalWrite(9, LOW); // Turn the rellay on
digitalWrite(9, HIGH); // turn the rellay off
delay(600);
pinMode(10, OUTPUT);
digitalWrite(10, LOW); // Turn the rellay on
digitalWrite(10, HIGH); // turn the rellay off
delay(600);
Start by putting all of the pinMode() calls in setup()
Then
  static unsigned long count = 0;
  count++;
  Serial.println(count);
Thank you very much for help, works very well.
That's good news.
I deliberately used a data type that will cope with big numbers but I assume that you will not be counting beyond 4,294,967,295 :slight_smile:
