Hello,
I need a code collecting data for how often a parking lot is occupied
I'm using an ultrasonic sensor. If the object is within 5 centimeters the parking lot is occupied otherwise it is unoccupied.
Every time a new object is occupying the parking lot, the counter has to add one to the previous counted amount.
The code I have created so far
#define led_red_pin 11
#define led_green_pin 9
#define trigPin 7
#define echoPin 5
int count;
float duration, distance;
pinMode(led_red_pin, OUTPUT);
pinMode(led_green_pin, OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) * 0.0343;
if (distance >= 5) {
Serial.println("Unoccupied");
digitalWrite(led_red_pin, LOW);
digitalWrite(led_green_pin, HIGH);
Serial.println(distance);
else if (distance <= 5 || distance >= 2) {
Serial.println("Occupied");
digitalWrite(led_red_pin, HIGH);
digitalWrite(led_green_pin, LOW);
count++;
Serial.println(count);
Hope you can help!
