heey there. I’m making a night rider project and when i want the leds to go back i need to use 2 in the for loop. i don’t know why i have to do it this way can somebody explain it to me? i wil mark the piece of code i mean.
You can’t use ‘color’ tags to mark things in a code block.
Also, it’s a good idea to format your code properly before posting. It makes it much easier to decipher:-
(I marked the relevant line.)
int ledpin[4] = {3, 5, 6, 9};
for (int i = 0; i < 4; i++)
pinMode(ledpin[i], OUTPUT);
for ( int i = 0; i < 4; i++)
for (int a = 0; a <= 255; a++)
analogWrite(ledpin[i], a);
delay(5);
for (int a = 255; a >= 0; a--)
delay(5);
for ( int i = 2; i > 0; i--) // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
delay(5);
delay(5);
I’m too tired to go over your code, but it’ll be easier now for the next viewer.
You appear to want to operate on the pins in reverse order, excluding the first and last pins. The index for the second to last pin is 2. Why is that a mystery.
Your indenting sucks, and there is no excuse for that, since Tools + Auto Format will fix what you messed up.
0 1 2 3
H L L L
L H L L
L L H L
L L L H
L L H L
L H L L
The first for loop takes care of the first 4 (forward). The second loop takes care of the last 2 (reverse).
If you would use 3 instead of 2, the last LED will light again. Also note that the the second loop does not go to 0 but stops at 1 so the first LED does not light again either.
There are many, many, many …, (you get the picture) ways to do this but here is one perhaps you’ll get something out of it other than a working lighting sequence.
// ... NAME EACH OF OUR PINS SO WE KNOW WHAT THE HELL THEY ARE FOR ...
const uint8_t pinLED_1 = 3;
const uint8_t pinLED_2 = 5;
const uint8_t pinLED_3 = 6;
const uint8_t pinLED_4 = 9;
// ... ALIAS LED STATE FOR READABILITY ...
const uint8_t LED_OFF = LOW;
const uint8_t LED_ON = HIGH;
// ... ARRAY OF ALL LEDS USED BY THE SEQUENCER ...
const uint8_t pinsLEDS[] = { pinLD1, pinLD2, pinLD3, pinLD4 };
// ... SOME CONSTANTS FOR USE IN UP-DATING TO LED"S BEING SEQUENCED ...
const size_t ARRAY_RANGE = sizeof(pinsLEDS) / sizeof(pinsLEDS[0]);
const size_t ARRAY_MIN = 0;
const size_t ARRAY_MAX = ARRAY_RANGE - 1;
const unsigned long DELAY_SOME = 100UL;
// ... SEQUENCE INCREMENT VALUE, +1 OR -1 ...
stat int increment = 1;
// ... INDEX OF LED IN ARRAY THAT IS CONSIDERED ON ...
static size_t index_pinsLEDS = 0;
// ... SET LED'S CURRENT STATE ...
for ( int i = ARRAY_RANGE; i--; )
digitalWrite(pinsLEDS[i], ((i == index_pinsLEDS) ? LED_ON : LED_OFF));
// ... UPDATE SEQUENCE ...
index_pinsLEDS += increment;
// ... IF WE'VE REACHED JUST SHORT OF EITHER END OF THE ARRAY ..
if ( (index_pinsLEDS < (ARRAY_MIN + 1)) || (index_pinsLEDS > (ARRAY_MAX - 1)) )
// ... NEGATE OUR INCREMENT VALUE SO NEXT OFFSET IS OTHER DIRECTION ...
increment = -increment;
// ... LET A LITTLE TIME PASS BEFORE WE UPDATE THE DISPLAY AGAIN ...
delay(DELAY_SOME);
// ... SET PIN MODE, AND STATE, FOR EVERY PIN IN THE ARRAY ...
for ( size_t i = ARRAY_RANGE; i--; )
pinMode(pinsLEDS[i], OUTPUT);
digitalWrite(pinsLEDS[i], LED_OFF);
