Counting
I am using barcode scanner with Arduino.
I need to count the number of the scanned items. The code correctly scan and identify the items, but count variable does not increment. I am not sure what's the problem, and will really appreciate any help.
///////////////// serial LCD
int x =1;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(15,14);   /////first one doesnt matter
int SCAN_ENTER = 0x5a; int SCAN_BREAK = 0xf0;
int breakActive = 0;
int clockPin = 3;
int dataPin = 2;
int ledPin = 13;  // When a SCAN_ENTER scancode is received the LED blink
int clockValue = 0;
byte dataValue;
byte scanCodes[10] = {0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46};
char characters[10] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
int quantityCodes = 10;
char buffer[64] = {};	// This saves the characters (for now only numbers)
char check[10]={'0','0','0','0','0','0','0','0','0','0'};
int bufferPos = 0;
int bufferLength = 64;
char tag1[5] = {'6','2','9','1','0'}; //masafi
char tag2[5] = {'6','2','9','1','1'}; //alain
char tag3[5] = {'6','2','9','7','0'}; //maiDubi
char tag4[5] = {'5','4','4','9','0'}; ////cocacola
char tag5[5] = {'0','1','2','0','0'}; ////7up
char tag7[5] = {'6','2','8','1','0'}; ////Al Rabie
char tag8[5] = {'4','7','9','2','0'}; ////Coconut water
int count=0;
	pinMode(dataPin, INPUT);
	pinMode(clockPin, INPUT);
	pinMode(ledPin, OUTPUT);
        mySerial.begin(9600);
        while(!Serial){ ; }
        while(!mySerial){ ; }
       mySerial.write(254); mySerial.write(128);
       mySerial.write("                "); // clear display;
       mySerial.write(254); // move cursor to beginning of first line
       //mySerial.write("welcome");
	dataValue = dataRead();
        Serial.print(dataValue);
	// If there is a break code, skip the next byte
	if (dataValue == SCAN_BREAK) {
		breakActive = 1;
	// Translate the scan codes to numbers
	// If there is a match, store it to the buffer
	for (int i = 0; i < quantityCodes; i++) {
		byte temp = scanCodes[i];
		if(temp == dataValue){
			if(!breakActive == 1){
				buffer[bufferPos] = characters[i];
				bufferPos++;
	//Serial.print('*'); // Output an asterix for every byte
	// Print the buffer if SCAN_ENTER is pressed.
	if(dataValue == SCAN_ENTER){
                //count=count+1; Serial.print("count=");Serial.println(char(count));delay(200);
		Serial.print("\nbuffer: ");
		// Read the buffer
		int i=0;
		if (buffer[i] != 0) {
			while(buffer[i] != 0) {
				Serial.print( buffer[i]);
                                 check[i]=buffer[i];
				 buffer[i] = 0;
				i++;
                 if (check[0] ==tag1[0]  && check[1] == tag1[1] && check[2] ==tag1[2]  && check[3] ==tag1[3] && check[4] ==tag1[4]  )
                    {Serial.println("\tMasafi"); mySerial.write("Masafi");count=count+1; Serial.print("count=");Serial.println(count);delay(200);}
                 if (check[0] ==tag2[0]  && check[1] == tag2[1] && check[2] ==tag2[2]  && check[3] ==tag2[3] && check[4] ==tag2[4] )
                    {Serial.println("\tAlain");mySerial.write("Alain");count=count+1; Serial.print("count=");Serial.println(count);delay(200); }
                 if (check[0] ==tag3[0]  && check[1] == tag3[1] && check[2] ==tag3[2]  && check[3] ==tag3[3] && check[4] ==tag3[4])
                    {Serial.println("\tMai Dubai");mySerial.write("Mai Dubai");count=count+1; Serial.print("count=");Serial.println(count);}
                 if (check[0] ==tag4[0]  && check[1] == tag4[1] && check[2] ==tag4[2]  && check[3] ==tag4[3] && check[4] ==tag4[4] )
                    {Serial.println("\tCocacola");mySerial.write("Cocacola");count=count+1; Serial.print("count=");Serial.println(count);}
                 if (check[0] ==tag5[0]  && check[1] == tag5[1] && check[2] ==tag5[2]  && check[3] ==tag5[3] && check[4] ==tag5[4])
                    {Serial.println("\t7UP");mySerial.write("7UP");count=count+1; Serial.print("count=");Serial.println(count);}
                 if (check[0] ==tag7[0]  && check[1] == tag7[1] && check[2] ==tag7[2]  && check[3] ==tag7[3] && check[4] ==tag7[4])
                    {Serial.println("\tAl Rabie");mySerial.write("Al Rabie");count=count+1;Serial.print("count=");Serial.println(count);delay(200); }
                 if (check[0] ==tag8[0]  && check[1] == tag8[1] && check[2] ==tag8[2]  && check[3] ==tag8[3] && check[4] ==tag8[4])
                    {Serial.println("\tCocunut Water");mySerial.write("Cocunut Water");count=count+1;Serial.write("count="); Serial.write(count);delay(200); }
		//Serial.print(" [count=]");
                //count = count+1;
                mySerial.write(count);
                for (int i=0; i <= 10; i++){ Serial.print(check[i]);  delay(10); }
		bufferPos = 0;
		// Blink the LED
		digitalWrite(ledPin, HIGH);
		delay(300);
		digitalWrite(ledPin, LOW);
	// Reset the SCAN_BREAK state if the byte was a normal one
	if(dataValue != SCAN_BREAK){
		breakActive = 0;
	dataValue = 0;
int dataRead() {
	byte val = 0;
	// Skip start state and start bit
	while (digitalRead(clockPin));  // Wait for LOW.
	// clock is high when idle
	while (!digitalRead(clockPin)); // Wait for HIGH.
	for (int offset = 0; offset < 8; offset++) {
		val |= digitalRead(dataPin) << offset; // Add to byte
// Skipping parity and stop bits down here.
	return val;
Attached is scan of the serial monitor.
Run2.pdf (179 KB)
Why are you trying to print eleven characters from a ten character buffer?
Your code is waaaay too long - are you being paid by the LOC?
This is not the cause of the problem.
Here I wanted to check that I am saving the scanned code correctly.
I will improve the code, once I complete the main functions.
Why not improve it now?
Why do you use Serial.write in some places, and Serial print in others?
Why does your code wander over the page?
Serial.print() >>>>> to print the values in the serial monitor
Serial.Write() >>>> To print the data to the serial LCD. This is the command they used in the LCD manual.
Any luck in identifying why count variable is not incremented correctly ?
AWOL:
I am more concern with the counting function.
FutureEngineer:
That don't make no sense.
Read your code again.
(Bugs like that can hide in plain view, when code is longer than it needs to be)
FutureEngineer:
I am more concerned with getting you to think and act like a future engineer.
Kindly refer to the LCD tutorial linked below.
https://www.sparkfun.com/tutorials/246
Even without mySerial.write command for the serial LCD, count is not incremented correctly.
I could not view the values on the serial monitor.
FutureEngineer:
Kindly refer to your code, above.
I just run the code without mySerial.Write command. Results are attached.
int x =1;
int clockPin = 3;
int dataPin = 2;
int clockValue = 0;
byte dataValue;
int bufferPos = 0;
int count=0;
        while(!Serial){ ; }
  ////////////////////////////////// dataRead() function
  byte val = 0;
	//return val;
dataValue = val;
	//dataValue = dataRead();
		breakActive = 1;
				bufferPos++;
                 count = count+1;
		// Read the buffer
		int i=0;
                                 check[i]=buffer[i];
				 buffer[i] = 0;
				i++;
                    {Serial.println("\tMasafi"); count=count+1; Serial.print("count=");Serial.println(count);delay(200);}
                    {Serial.println("\tAlain");count=count+1; Serial.print("count=");Serial.println(count);}
                    {Serial.println("\tMai Dubai");count=count+1; Serial.print("count=");Serial.println(count);}
                    {Serial.println("\tCocacola");count=count+1; Serial.print("count=");Serial.println(count);delay(200);}
                    {Serial.println("\t7UP");count=count+1; Serial.print("count=");Serial.println(count);delay(200);}
                    {Serial.println("\tAl Rabie");count=count+1;Serial.print("count=");Serial.println(count);delay(200);}
                    {Serial.println("\tCocunut Water");count=count+1;Serial.write("count="); Serial.write(count);delay(200); }
                count = count+1;
                //mySerial.write(count);
                for (int i=0; i < 10 ; i++){ Serial.print(check[i]);  delay(10); }
		bufferPos = 0;
		// Blink the LED
		digitalWrite(ledPin, HIGH); delay(300);digitalWrite(ledPin, LOW);
		breakActive = 0;
	dataValue = 0;
Run3.pdf (205 KB)
AWOL:
please be specific, which part in my code resulted in the problem ?
Serial.write("count=");"without Serial.write"?
Please, start paying attention.
I removed all mySerial.write commands but still same results. Kindly refer to the code below.
int clockPin = 3;
int dataPin = 2;
int clockValue = 0;
byte dataValue;
int bufferPos = 0;
int count=0;
  byte val = 0;
	//return val;
dataValue = val;
		breakActive = 1;
				bufferPos++;
                 count = count+1;
		// Read the buffer
		int i=0;
                                 check[i]=buffer[i];
				 buffer[i] = 0;
				i++;
                count = count+1;
		bufferPos = 0;
		// Blink the LED
		breakActive = 0;
	dataValue = 0;
OK, it's clear now that you're simply not paying attention and have no interest in finding your problem, just wanting to be spoon-fed.
That's not my thing. I'm out.
AWOL:
I honestly don't know what you are talking about.
Thanks any way.
FutureEngineer:
Thanks any way.
When you tell me you've removed the Serial.writes from your code then post your code and I can see a Serial.write, then I know you're not paying attention.
Your code is too long.
AWOL:
I just remove the one serial.write for the coconut water, but still counting problem is not solved.
int clockPin = 3;
int dataPin = 2;
int clockValue = 0;
byte dataValue;
int bufferPos = 0;
int count=0;
  byte val = 0;
	//return val;
dataValue = val;
		breakActive = 1;
				bufferPos++;
                 count = count+1;
		// Read the buffer
		int i=0;
                                 check[i]=buffer[i];
				 buffer[i] = 0;
				i++;
                    {Serial.println("\tCocunut Water");count=count+1;Serial.print("count="); Serial.print(count);delay(200); }
                count = count+1;
		bufferPos = 0;
		// Blink the LED
		breakActive = 0;
	dataValue = 0;
