'countof' was not declared in this scope
I am new to the forum and a novice with Arduino.
There's a problem in my sketch.
[code]
#include <SPI.h> //Library for SPI communication (Pre-Loaded into Arduino)
#include <SD.h> //Library for SD card (Pre-Loaded into Arduino)
#include "DHT.h"
#include <ThreeWire.h>
#include <RtcDS1302.h>
#define DHTTYPE DHT11 // DHT 11
uint8_t DHTPin = 6;
DHT dht(DHTPin, DHTTYPE);
float Temperature;
float Humidity;
ThreeWire myWire(8,5,2); // IO, SCLK, CE
RtcDS1302 Rtc(myWire);
const int chipSelect = 10; //SD card CS pin connected to pin 4 of Arduino
// Setup Serial connection
pinMode(DHTPin, INPUT);
dht.begin();
Serial.print("compiled: ");
Serial.print(DATE);
Serial.println(TIME);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
// printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
    // Common Causes:
    //    1) first time you ran and the device wasn't running yet
    //    2) the battery on the device is low or even missing
    Serial.println("RTC lost confidence in the DateTime!");
    Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
    Serial.println("RTC was write protected, enabling writing now");
    Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
    Serial.println("RTC was not actively running, starting now");
    Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
    Serial.println("RTC is older than compile time!  (Updating DateTime)");
else if (now > compiled)
    Serial.println("RTC is newer than compile time. (this is expected)");
    Serial.println(" ");
else if (now == compiled)
    Serial.println("RTC is the same as compile time! (not expected but all is fine)");
Initialize_SDcard();
Write_SDcard();
Read_TempHum();
delay(1000); //Wait for 5 seconds before writing the next data
void Read_TempHum()
Temperature = dht.readTemperature();
Humidity = dht.readHumidity();
Serial.print("Temperature = ");
Serial.println(Temperature);
Serial.print("Humidity = ");
Serial.println(Humidity);
// delay(1000);
void Initialize_SDcard()
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect))
Serial.println("Card failed, or not present");
// don't do anything more:
return;
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("LoggerCD.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile)
dataFile.println("Temperature,Humidity"); //Write the first row of the excel file
dataFile.close();
void Write_SDcard()
if (dataFile)
printDateTime;
dataFile.print(",");
dataFile.print(Temperature); //Store date on SD card
dataFile.print(","); //Move to next column using a ","
dataFile.print(Humidity); //Store date on SD card
dataFile.println(); //End of Row move to next row
dataFile.close(); //Close the file
Serial.println("SD card writing failed");
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
[code]
No matter what I try, every solution creates a new problem.
Please HELP!
Welcome to the forums. Please take a few minutes and read: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
Then, go back and edit your post to include code tags around your code. It is also helpful if you auto format your code in the IDE before posting (Ctrl-T)
The problem with the posted code is it's not in those so called code tags.
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
An example of code tag use.
Would sizeof() be a better choice?
Hi @haddocks
first read: How to get the best out of this forum
second: redo your inicial post and put you code between tags </>
ArduinoForum
then try this code:
RV mineirin
#include "DHT.h"
uint8_t DHTPin = 6;
float Temperature;
float Humidity;
ThreeWire myWire(8, 5, 2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
  dht.begin();
Serial.print(__DATE__);
    Serial.println(__TIME__);
  Rtc.Begin();
    // Common Causes:
  if (now < compiled)
  Write_SDcard();
  Read_TempHum();
void Read_TempHum()
  // delay(1000);
    return;
  if (dataFile)
    dataFile.close();
void Write_SDcard()
  if (dataFile)
    printDateTime;
#define countof(a) (sizeof(a) / sizeof(a[0]))
             dt.Month(),
             dt.Day(),
             dt.Year(),
             dt.Hour(),
             dt.Minute(),
             dt.Second() );
Wait... what? There is a [code] tag.
Oh, that shoud be [/code].
Thank you all so much; I'm going to study the rules carefully before I continue.
With best regards,
Haddocks
