Bonjour,
Je débute sur Arduino, j'ai pour projet de lire un fichier sur mon serveur Web, afin de mettre à jour des variables sur mon Arduino.
J'ai acheté Ethernet Shield (ENC28J60), j'utilise la libraire EtherShield.h.
Je me suis inspiré des exemples, mais je recois un message d'erreur que je ne comprend pas lors de la compilation :
EtherShield_readpachube.pde:138:1: error: unterminated #ifdef
EtherShield_readpachube.pde: In function 'void loop()':
EtherShield_readpachube:143: error: invalid conversion from 'void ()(uint8_t, uint16_t)' to 'void ()(uint8_t, uint16_t, uint16_t)'
EtherShield_readpachube:143: error: initializing argument 4 of 'void EtherShield::ES_client_browse_url(prog_char*, char*, prog_char*, void (*)(uint8_t, uint16_t, uint16_t))'
Le code que je suis entrain d'adapter :
#include <EtherShield.h>
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x25};
static uint8_t myip[4] = {192,168,1,56};
// Default gateway. The ip address of your DSL router. It can be set to the same as
// websrvip the case where there is no default GW to access the
// web server (=web server is on the same lan as this host)
static uint8_t gwip[4] = {192,168,1,254};
// Pachube declarations
#define PORT 80 // HTTP
#define HOSTNAME "www.Monserveur.fr" // API key
static uint8_t websrvip[4] = { 78,204,xxx,xx }; // Get pachube ip by DNS call
#define WEBSERVER_VHOST "www.Monserveur.fr"
#define HTTPPATH "/txt/test.txt" // Set your own feed ID here
static uint8_t resend=0;
static int8_t dns_state=0;
EtherShield es=EtherShield();
#define BUFFER_SIZE 550
static uint8_t buf[BUFFER_SIZE+1];
void browserresult_callback(uint8_t statuscode,uint16_t datapos){
if (datapos != 0)
// now search for the csv data - it follows the first blank line
// I'm sure that there is an easier way to search for a blank line - but I threw this together quickly
// and it works for me.
uint16_t pos = datapos;
while (buf[pos]) // loop until end of buffer (or we break out having found what we wanted)
while (buf[pos]) if (buf[pos++] == '\n') break; // find the first line feed
if (buf[pos] == 0) break; // run out of buffer
if (buf[pos++] == '\r') break; // if it is followed by a carriage return then it is a blank line (\r\n\r\n)
if (buf[pos]) // we didn't run out of buffer
pos++; //skip over the '\n' remaining
Serial.println((char*)&buf[pos]);
void setup(){
#ifdef FLASH_VARS
Serial.println("Ethershield Pachube Read example, using Flash");
#else
Serial.println("Ethershield Pachube Read example using ram");
#endif
// Initialise SPI interface
es.ES_enc28j60SpiInit();
// initialize ENC28J60
es.ES_enc28j60Init(mymac);
//init the ethernet/ip layer:
es.ES_init_ip_arp_udp_tcp(mymac, myip, PORT);
// init the web client:
es.ES_client_set_gwip(gwip); // e.g internal IP of dsl router
static uint32_t timetosend;
uint16_t dat_p;
int sec = 0;
long lastDnsRequest = 0L;
int plen = 0;
dns_state=0;
while(1) {
// handle ping and wait for a tcp packet - calling this routine powers the sending and receiving of data
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
dat_p=es.ES_packetloop_icmp_tcp(buf,plen);
if( plen > 0 ) {
// We have a packet
// Check if IP data
Serial.println("PAcket Oui");
if (dat_p == 0) {
if (es.ES_client_waiting_gw() ){
// No ARP received for gateway
continue;
// It has IP data
if (dns_state==0){
sec=0;
dns_state=1;
lastDnsRequest = millis();
es.ES_dnslkup_request(buf,(uint8_t*)WEBSERVER_VHOST);
continue;
if (dns_state==1 && es.ES_udp_client_check_for_dns_answer( buf, plen ) ){
dns_state=2;
es.ES_client_set_wwwip(es.ES_dnslkup_getip());
if (dns_state!=2){
// retry every minute if dns-lookup failed:
if (millis() > (lastDnsRequest + 60000L) ){
dns_state=0;
// don't try to use web client before
// we have a result of dns-lookup
continue;
dns_state=2;
// If we have IP address for server and its time then request data
if( dns_state == 2 && millis() - timetosend > 10000) // every 10 seconds
timetosend = millis();
#ifdef FLASH_VARS
// note the use of PSTR - this puts the string into code space and is compulsory in this call
// second parameter is a variable string to append to HTTPPATH, this string is NOT a PSTR
es.ES_client_browse_url(PSTR(HTTPPATH), NULL, PSTR(HOSTNAME), &browserresult_callback);
#else
es.ES_client_browse_url(HTTPPATH, NULL, HOSTNAME, &browserresult_callback);
#endif
Merci pour votre aide
