Coutdown timer - problème de code?
Bonjour à tous,
J'ai récupérer un code sur une application android "arduino works" pour faire un countdown timer.
La compilation et le televersement se fait correctement mais rien ne fonctionne.
composition du projet : module led matrix 32x8 , arduino nano et 3 inter.
je met le code, le plan de cablage et les fichiers ci-dessous
si qqun voit un problème quelque part
merci
#include <LEDMatrixDriver.hpp>
#include "SystemFont3x7.h"
// Font constant
#define FONT_LENGTH             0
#define FONT_FIXED_WIDTH        2
#define FONT_HEIGHT             3
#define FONT_FIRST_CHAR         4
#define FONT_CHAR_COUNT         5
#define FONT_WIDTH_TABLE        6
// pin definition
#define PIN_BUZZER        6
#define PIN_10SEC         2
#define PIN_5MIN          3
#define PIN_START         4
#define LEDMATRIX_CS_PIN  12
// Number of 8x8 segments you are connecting
const int LEDMATRIX_SEGMENTS = 4;
const int LEDMATRIX_WIDTH    = LEDMATRIX_SEGMENTS * 8;
// The LEDMatrixDriver class instance
LEDMatrixDriver matrix(LEDMATRIX_SEGMENTS, LEDMATRIX_CS_PIN);
unsigned long startTime ;
unsigned long elapseTime ;
unsigned long countDown=0;
bool bCountDown = false;
    pinMode(PIN_BUZZER, OUTPUT);
    pinMode(PIN_10SEC, INPUT_PULLUP);
    pinMode(PIN_5MIN, INPUT_PULLUP);
    pinMode(PIN_START, INPUT_PULLUP);
    // init the display
    matrix.setEnabled(true);
    matrix.setIntensity(2);   // 0 = low, 10 = high
    matrix.clear();
    draw_string(2,1, System3x7, "00:00");
    matrix.display();
void draw_buffer ( int x, int y ,const uint8_t *font, uint16_t font_index, byte width  )
    int height =8;
    byte mask  ;
    byte val;
    for( int dx = 0; dx < width; dx++ )
      val = pgm_read_byte(font + font_index + dx);
      mask = B00000001;
      for( int dy = 0; dy < height; dy++ )
          if (x+dx >=LEDMATRIX_WIDTH)
                  continue;
          if (y+dy >=8) // height is 8
                  continue;
        matrix.setPixel(x + dx, y + dy, (bool)(val & mask ));
        // shift the mask by one pixel to the right
        mask = mask << 1;
byte draw_char(int x, int y, const uint8_t *font, char ch)
    byte width;
    uint16_t index = 0;
    uint8_t firstChar = pgm_read_byte(font + FONT_FIRST_CHAR);
    uint8_t charCount = pgm_read_byte(font + FONT_CHAR_COUNT);
    if (ch < firstChar || ch >= (firstChar + charCount))
        return 0; // outside the font
    // fixed width
     if   (pgm_read_byte(font + FONT_LENGTH) == 0
     &&  pgm_read_byte(font + FONT_LENGTH + 1) == 0)
        // zero length is flag indicating fixed width font (array does not contain width data entries)
        width = pgm_read_byte(font + FONT_FIXED_WIDTH);
        index = (ch-firstChar) *  width + FONT_WIDTH_TABLE;
        width = pgm_read_byte(font + FONT_WIDTH_TABLE + (ch-firstChar));
        // variable width font, read width data, to get the index
        for (uint8_t i = firstChar; i < ch; i++)
            index += pgm_read_byte(font + FONT_WIDTH_TABLE + (i-firstChar));
        index +=   charCount + FONT_WIDTH_TABLE ;
    draw_buffer(  x,   y,font, index, width);
    return width;
void draw_string(int x, int y, const uint8_t *font, String str)
    int x1 = x;
    for (int i =0; i<str.length(); i++)
       x1 += draw_char(x1, y, font, str.charAt(i)) + 1; // 1 px spacing
void show_countdown()
    if (countDown > 60* 60)
        countDown = 0;
    int mm = countDown/60;
    int ss =  countDown - mm*60;
    char buf[6];
    matrix.clear();
    sprintf(buf,"%02d:%02d", mm,ss);
    draw_string(2,1, System3x7, buf);
    matrix.display();
    int minute=0, second=0, ms=0;
    if (bCountDown)
        matrix.display();
        elapseTime = millis()  - startTime;
        if (countDown*1000  > elapseTime)
            elapseTime = countDown*1000 - elapseTime ;
            int totalsecond = elapseTime /1000;
            minute = totalsecond / 60;
            second = totalsecond - 60 * minute  ;
            ms = elapseTime - totalsecond*1000;
        else // reach
            minute = 0;  second = 0 ; ms = 0;
            bCountDown     = false;
        char buf[9];
        matrix.clear();
        sprintf(buf,"%02d:%02d.%01d",minute, second,(int)(ms/100 ) );
        matrix.display();
        if (!bCountDown)
           tone(PIN_BUZZER, 400, 500); delay(2000);
           noTone(PIN_BUZZER);
    else // setup countdown time
        if (digitalRead(PIN_10SEC)==LOW)
            delay(50);
            while (digitalRead(PIN_10SEC)==LOW);
            delay(50);
            countDown += 10;
            show_countdown();
        if (digitalRead(PIN_5MIN)==LOW)
            delay(50);
            while (digitalRead(PIN_5MIN)==LOW);
            delay(50);
            countDown +=  5 * 60  - (countDown %300)  ;
            show_countdown();
        if (digitalRead(PIN_START)==LOW)
            delay(50);
            while (digitalRead(PIN_START)==LOW);
            delay(50);
            bCountDown = true;
            startTime = millis();
arduino_matrix4_countdown.zip (23,2 Ko)
Bonjour,
Ton afficheur est mal connecté. Dans la doc de la librairie on lit:
Recommended pins for Arduino Uno:
  • DIN is connected to 11
  • CLK is connected to 13
  • CS is connected to 9
ah super merci
j'avais pas pensé à regarder la librairie.
Merci encore je test ce soir en rentrant.
Dans le programme il faut aussi changer
en
#define LEDMATRIX_CS_PIN 9
super ça fonctionne merci
Super! :+1:
Petite remarque:
ici:
            delay(50);
Ce n'est pas très efficace pour traiter les rebonds. Il faudrait faire
                delay(50);
Idem pour tous les boutons.
Bonsoir @starz91,
En complément de ce que vous a dit @kamill , il me semble que le programme présente plusieurs bugs qui concernent la prise en compte d'un nouveau décompte :
A la fin d'un décompte de temps, la variable countDown n'est pas remise à zéro, du coup toute nouvelle incrémentation de secondes est fausse puisqu'elle prend en compte les secondes de l'ancien décompte !
Je vous suggère donc de corriger ici en ajoutant countDown = 0; :
if (!bCountDown)
      noTone(PIN_BUZZER);
      countDown = 0;
De même dans le code qui gère l'appui sur le BP qui vient incrémenter le temps à décompter de 5 minutes vous devez supprimer - (countDown % 300) car si des secondes ont été incrémentées par le BP de 10 secondes elles seront supprimées :
if (digitalRead(PIN_5MIN) == LOW)
      delay(50);
      while (digitalRead(PIN_5MIN) == LOW) delay(50);
      countDown +=  5 * 60 ;  //- (countDown % 300)  ;
      show_countdown();
Bonne soirée.
Bonsoir philippe86220,
merci infiniment pour cette info. je corrigerai le code et testerai pour le coup.
J'attends votre retour.
Bonne soirée
bonjour, votre modification fonctionne au petits oignons.
merci
maintenant faut que je trouve un moyen de remplasser le buzzer par quelque chose de plus efficace car c'est vraiment peu audible.
Super alors. Je suis content pour vous.
Vous savez que vous pouvez changer la tonalité de votre buzzer.
Tapez arduino buzzer, ça m'étonnerait que vous ne trouviez pas la tonalité souhaitée.
Bonne journée
https://arduinogetstarted.com/fr/reference/tone
https://www.carnetdumaker.net/articles/jouer-des-notes-de-musiques-avec-une-carte-arduino-genuino/
