Covert degrees C to degrees F LCD display
Not proficient in any coding (besides Basic & Boolean from 20 yrs ago). Retired and just playing around.
I have managed to get Temp & Humidity to display correctly in the serial monitor (degree symbol (176) appears as a square so disabled line.
On my 16x2 LCD I2c the display reads Temp: 24.9076.82 and for the life of me cannot remove the degree C (I figure it is the default for the DHT11).
Here’s part of my code: What am I missing?
<void setup()
//Initialize serial port
Serial.println(“DHT11 sensor testing”);
dht.begin();
lcd.begin(16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
//Initialize the DHT sensor
dht.begin();
int tempReading = analogRead(tempPin);
float converted = 0.0;
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
//Fahrenheit
//T(°F) = T(°C) × 9/5 + 32
converted = ( temp * 1.8 ) + 32;
Serial.print(“Temp : “);
Serial.print(converted);
//Print degree symbol
//Serial.write( 176);
Serial.println(” F”);
Serial.print("Humidity ");
Serial.println(hum);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Temp: “);
lcd.print(temp);
lcd.print(converted);
lcd.print(” ");
//lcd.print((char)176);
lcd.print(“F”);
lcd.setCursor(0,1);
lcd.print(“Hum: “);
lcd.print(hum);
lcd.print(” %”);
//2000mS delay between reads>
What am I missing?
  1. Code tags.
  2. The rest of the code.
Here’s a working example:
/* YourSmartDuino-EM  EZP-TEMPERATURE-HUMIDITY
  - WHAT IT DOES: Measures and displays Temperature and Humidity
  - Changes from C to F with a switch
  - Uses the KEYES Easy-Plug Modules
  - V3. 2/13/2019
   Questions: terry@yourduino.com
  - SEE the comments after "//" on each line below
  - CONNECTIONS: KEYES Easy-Plug Control Board V2.0
    NOTE: Different Software examples use a different sets of modules.
  /*-----( Import needed libraries )-----*/
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
#include <dhtnew.h>     // DHT11 Temperature-Humidity Sensor
// [Rob Tillaart's new version: It finds out what module is being used
/*----------------( Declare Constants and Pin Numbers )-------------------*/
#define LED_MODULE_PIN    6
#define BUZZER_PIN        7
#define ONBOARD_LED_PIN   13
//----( DIGITAL INPUT Pins)----
#define SWITCH_PIN        A3   // Used for a variety of On-OFF Devices
#define DHT11_PIN         8    // Temperature/Humidity Sensor
//------( LOCAL DEFINITIONS )---------
#define ON       1
#define OFF      0
/*--------------------( Declare objects )-------------------------*/
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);   // Define the LCD Display
DHTNEW Temp_Humid_Sensor(DHT11_PIN);   // Define the DHT11 Temperature / humidity sensor
/*------------------------( Declare Variables )-----------------------------------*/
float temperatureC;
float temperatureF;
float humidityPercent;
boolean TempIsC = true;   // For switching between C and F
void setup()   /******************* SETUP: RUNS ONCE *************************/
  Serial.begin(115200);        // Start up the Serial Monitor
  lcd.begin(16, 2);  // initialize the lcd for 16 chars 2 lines, turn on backlight
  lcd.noBacklight();
  lcd.backlight(); // finish with backlight on
  lcd.setCursor(0, 0); //Start at character 0 on line 0
  lcd.print(F("YourSmart!Duino"));
  lcd.setCursor(0, 1); //Start at character 0 on line 0
  lcd.print(F("YourDuino.com"));
  pinMode(LED_MODULE_PIN, OUTPUT);
  pinMode(ONBOARD_LED_PIN, OUTPUT);
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(SWITCH_PIN, INPUT_PULLUP);
  Serial.println("Option 4: Temperature / Humidity");
  //-----------1234567890123456----------
  lcd.print(F("4: Temp-Humidity"));
  lcd.setCursor(0, 1); //Start at character 0 on line 1
  lcd.print(F("DHT11 Sensor "));
  delay(2000);
}//--(end setup )---
void loop()   /********************** LOOP: RUNS CONSTANTLY ************************/
  /*-------------( Option 4 )---------------
          User connects:
          switch to A3
          DHT11 Temperature/Humidity sensor to D8
          LCD display to I2C
  Temp_Humid_Sensor.read();
  lcd.print("Humidity   = ");
  humidityPercent = Temp_Humid_Sensor.humidity;
  lcd.print(humidityPercent, 0);
  lcd.print("%");
  if (digitalRead(SWITCH_PIN ) == OFF)  //Active pushbutton
    TempIsC = true;
    TempIsC = false;
  if (TempIsC == true)
    lcd.print("Temperature= ");
    temperatureC = Temp_Humid_Sensor.temperature;
    lcd.print(temperatureC, 0);
    lcd.print("C");
    temperatureF = (temperatureC * (9.0 / 5.0)) + 32.0;
    lcd.print(temperatureF, 0);
    lcd.print("F");
}//--(end main loop )---
/*--------------------( Declare User-written Functions )------------------------*/
//NONE
//*********( THE END )***********
Here’s the part where you print to the LCD
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Temp: ");
 lcd.print(temp);                // <----- try removing this line
 lcd.print(" ");
 lcd.print("F");
 lcd.setCursor(0,1);
 lcd.print("Hum:  ");
 lcd.print(hum);
 lcd.print(" %");
I don’t think you need to print both temp and converted.
You are printing Temp: then temp and then converted to the LCD. 24.90 is Celsius, 76.82 is Fahrenheit
Steve
PaulS:
  1. Code tags.
Will post entire code next time, my apologies and was my first real request for help here!
Then have a look at this from the stickies at the top of the forum page:
Read this before posting a programming question ...
GypsumFantastic:
lcd.clear();
lcd.setCursor(0,0);
lcd.print(” ");
lcd.print(“F”);
lcd.setCursor(0,1);
lcd.print(“Hum:  “);
lcd.print(hum);
lcd.print(” %”);
I don't think you need to print both temp and converted.
Thank you Gypsum, that fixed it.
evanmars:
I read through the stickies B4 posting, apparently I missed something!
Care to reference?
terryking228:
- V3. 2/13/2019
 - SEE the comments after “//” on each line below
/-----( Import needed libraries )-----/
// See Library “Docs” folder for possible commands etc.
// [Rob Tillaart’s new version: It finds out what module is being used
/----------------( Declare Constants and Pin Numbers )-------------------/
#define ON       1
#define OFF      0
/--------------------( Declare objects )-------------------------/
/------------------------( Declare Variables )-----------------------------------/
float temperatureC;
float temperatureF;
 lcd.noBacklight();
 lcd.print(F(“YourSmart!Duino”));
 lcd.print(F(“YourDuino.com”));
Serial.println(“Option 4: Temperature / Humidity”);
 lcd.print(F(“4: Temp-Humidity”));
delay(2000);
}//–(end setup )—
User connects:
         switch to A3
         LCD display to I2C
 lcd.print(“Humidity   = “);
 lcd.print(”%”);
   TempIsC = true;
   TempIsC = false;
   lcd.print(“C”);
   lcd.print(“F”);
}//–(end main loop )—
/--------------------( Declare User-written Functions )------------------------/
//NONE
//( THE END )**
Thank you Terry, had some debug errors that are beyond my ability but will research your methods down the road after the basics.
JMcGraw:
Care to reference?
Disregard, found the section regarding Code Tags.
Sorry!
Latest Rob Tillart library etc. here:
https://arduinoinfo.mywikis.net/wiki/DHT11-Humidity-TempSensor
download the .zip
