system
July 19, 2014, 9:59am
1
I have installed the cozir library 1.0.3 for the cozir co2 module in Arduino 1.0.5 on ubuntu. When I try to compile I get the error :-
cozir.cpp:14:19: error: Cozir.h: No such file or directory
then others caused by this, even though the Cozir.h file is installed in the same directory.
What mistake am I making ?
If I comment out //#include "cozir.h" from the code below I get the error
error: ‘COZIR’ does not name a type
#include <SoftwareSerial.h>
#include "cozir.h"
SoftwareSerial nss(3,2);
COZIR czr(nss);
Serial.println("Setup");
Serial.println("Loop");
float t = czr.Celsius();
float f = czr.Fahrenheit();
float h = czr.Humidity();
uint16_t c = czr.CO2();
Serial.print("Celcius = ");Serial.println(t);
Serial.print("Fahrenheit = ");Serial.println(f);
Serial.print("Humidity = ");Serial.println(h);
Serial.print("CO2 = ");Serial.println(c);
delay(3000);
check if the include is case sensitive.
cozir.h --> Cozir.h
The include statement in the .cpp file should be identical to the include in your sketch and identical to the actual .h file name.
hope this helps,
Where exactly is the file installed ?
Using
#include "cozir.h"the header file should be in the same directory as you program.
Compare that with #include <SoftwareSerial.h>which indicates that the header file is in the libraries folder.
COZIR is undefind for compiler because compiler does not able to find out cozir.h (for definition).
system
July 19, 2014, 11:16am
5
The library is in the arduino/libraries folder.
I changed the include in the sketch to #include <cozir.h> and the declaration in the cpp file from Cozir to cozir
It now works many thanks for all the help.
