CP2102N USB to UART Issue
Am trying to troubleshoot why my computer isn't recognizing the CP2102N as COM Port. I have tried two different computers, one PC and one Mac, different cables, uninstalling and reinstalling the drivers. I've attached the board schematic below. Here is the link to the IC itself. Not sure what my other options to troubleshoot can be. I've ordered the generic Xbee to usb converter off of amazon to see if it works to either narrow down the issue to my hardware or computer.
XBee Adapter Board v1.pdf (20.7 KB)
Try it on a PC/laptop with Linux installed.
I've never needed to install a driver for any USB-serial adapter, with any of CP2102, CH340 or FT232 chips.
What are the values of the resistors and capacitors
What is the PN for D1-D4
SD1206S040S2R0
C1 = 4.7uF
C2 = 0.1uF
C3 = 1uF
C4 = 0.1uF
C5 = 1uF
C6 = 47pF
R1 = 91Ω
R2 = 91Ω
R3 = 6.8Ω
R4 = 6.8Ω
R5 = 6.8Ω
R6 = 86.6Ω
R7 = N/A
R8 = N/A
R9 = 20KΩ
R10 = 50KΩ
The schematic was incorrectly drawn. Here is the updated section with the R9 and R10 routing.
That is very small
The absolute max current for VDD is 100mA and I would not draw any more that 80mA.
For the LEDs connected to 3.3V you are already using 40mA maybe even more if VDD is at it's max and the Vf of the LED is at it's min.
So if the xbee module uses more that 40mA you have a big problem.
Attached a photo for the calculation of supply voltage being 3.3V and Forward Voltage being 3.2V with a max current being 20mA. 5 Ω was the minimum the next one up available for purchase was 6.8Ω
See post #9
Appreciate your concern with the LED, I will dive into that later. However not the nature of the issue I'm seeking guidance with.
If your xbee draws more than 40mA than don't expect the CP2102 to work.
The XBee isn't connected. It is not required to be connected in order to allow a COM Port to appear, IRT the data sheet.
It really might be.
You might want to consider that what you see as the issue is only a symptom of another problem, as @jim-p is pointing out.
If you don't tell me these things and show an incorrect schematics then I have no way of helping you.
Show a good schematic of what you actually have and what is actually connected.
The LEDs in question with the 6.8Ω resistors aren't operational under a 'USB Powered State'
There are 3 possible power supply options through this board. 3.3V, 5V, or 5V USB through the CP2102 Vreg.
Only one power source is supplied at a time, in this case, I am trying to connect the CP2102 with a computer via USB. The only LED that would be operational would be D5. Unsoldered the LED and it still poses the same issue.
The schematic is fine, the XBEE uses a pin header to interface with the board. This is how the board can be connected and not connected.
Not much I can do without the correct information.
You already have one mistake on your schematics maybe there are more.
You are already drawing a lot of current from VDD, maybe somewhere else you are drawing more.
Since the Xbee module can draw up to 215mA your design will burn out the CP2102, maybe you already burned it out.
If you read the CP2102 data sheet you would already know tthis, so I have to wonder what you schematic is actually supposed to show.
Lets start over Jim, because this isn't going anywhere.
Here is the correct schematic with all the values. Where do you see issues? Keep in mind all the LED/Resistors have been unsoldered from the board.
Am trying to troubleshoot why my computer isn't recognizing the CP2102N as COM Port. I have tried two different computers, one PC and one Mac, different cables, uninstalling and reinstalling the drivers. I've attached the board schematic below. Here is the link to the IC itself. Not sure what my other options to troubleshoot can be. I've ordered the generic Xbee to usb converter off of amazon to see if it works to either narrow down the issue to my hardware or computer. The purpose of this board is to allow three different power sources to the XBEE; 3.3V, 5V, and 5V via USB. Both the 5V would go through the Vreg to bring it to 3.3V. Only time USB would be used it to configure the XBEE which interfaces via header pins. Only one power source would be supplied at a time.
Update: From a previous thread that had to be deleted, unsoldered the LED/resistors and the issue still persists. (R1/R2/R3/R4/R5/R6)
XBee Adapter Board v1.pdf (20.5 KB)
