This code is not 100% perfect but I believe it can be understood without comments.
Here is my challenge. The first person to tell me what it does and is will get $20 via PayPal. Seriously
Good Luck.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
long randomNumber;
int randomA;
int randomB;
int randomC;
int randomD;
int randomCode;
int codeVal;
int realNumber;
int realA;
int realB;
int realC;
int realD;
int value;
int count;
int state;
int lastState;
int counter;
int relayPin = 5;
int SW = 2;
int CLK = 9; // Pin 9 to clk on encoder
int DT = 8; // Pin 8 to DT on encoder
lcd.begin(16, 2);
randomSeed(analogRead(0));
pinMode (SW, INPUT);
pinMode (CLK, INPUT);
pinMode (DT, INPUT);
pinMode (relayPin, OUTPUT);
//rotation = digitalRead(CLK);
counter = 5;
count = 0;
lastState = digitalRead(CLK);
lcd.setCursor(0, 0);
lcd.print(" Code #");
lcd.setCursor(0, 1);
lcd.print(" Access #");
lcd.setCursor(11, 0);
lcd.print(randomCode);
if (count == 0) {
randomGen();
if (digitalRead(SW) == HIGH); {
count++;
switch (count) { //RotPosition = counter
case 1:
select();
realA = (counter * 1000);
lcd.setCursor(11, 1);
lcd.print(counter);
case 2:
lcd.print("*");
select();
realB = (counter * 100);
lcd.setCursor(12, 1);
lcd.print(counter);
case 3:
lcd.print("*");
select();
realC = (counter * 10);
lcd.setCursor(13, 1);
lcd.print(counter);
case 4:
lcd.print("*");
select();
realD = (counter * 10);
lcd.setCursor(14, 1);
lcd.print(counter);
case 5:
lcd.print("*");
check();
int select() {
state = digitalRead(CLK);
if (state != lastState) {
if (digitalRead(DT) != state)
counter++;
counter--;
count++;
int check() {
realNumber = (realA + realB + realC + realD);
codeVal = map (randomCode, 9999, 1111, 1111, 9999);
if (codeVal == realNumber) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" * ACCESS ");
lcd.setCursor(0,1);
lcd.print(" GRANTED ");
digitalWrite(relayPin, HIGH);
delay(3000);
digitalWrite(relayPin, LOW);
count = 0;
counter = 5;
lcd.clear();
int randomGen() {
randomNumber = random(1, 10);
randomA = (randomNumber * 1000);
randomB = (randomNumber * 100);
randomC = (randomNumber * 10);
randomD = randomNumber;
randomCode = (randomA + randomB + randomC + randomD);
delay(100);
delay(100);
count++;
return randomCode;
