Crashing when Wi-Fi got Disconnected
Hello, I have a project where I am trying to implement FreeRTOS with Firebase ESP Client since I wanted to log some data to the Firebase Realtime Database. However, it keeps on triggering the WDT Reset when my Wi-Fi get disconnected. I also have another different ESP32 board and the same issue persists. Here is the sample code:
#include <Arduino.h>
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include <addons/RTDBHelper.h>
#include <addons/TokenHelper.h>
#include <time.h>
#define WIFI_SSID ""
#define WIFI_PASSWORD ""
#define DATABASE_URL ""
#define API_KEY ""
#define USER_EMAIL ""
#define USER_PASSWORD ""
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseJson json;
FirebaseConfig config;
void wifi(void *param)
  String uid = "";
  String databasePath, parentPath;
  int timestamp = 0;
  bool timeSynched = false;
  unsigned long previousTimeSync = 0;
  unsigned long wifiConnectedMillis = 0;
  unsigned long wifiReconnectMillis = millis();
  struct tm timeinfo;
  for (;;)
    if (WiFi.status() != WL_CONNECTED)
      if (wifiConnectedMillis == 0)
        WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
        Serial.print("Connecting to Wi-Fi");
        if (millis() - wifiReconnectMillis > 1000)
          Serial.println("Reconnecting to WiFi");
          WiFi.reconnect();
      unsigned long wifiTmo = millis();
      while (WiFi.status() != WL_CONNECTED && millis() - wifiTmo < 5000)
        Serial.print(".");
        delay(300);
      if (WiFi.status() == WL_CONNECTED)
        wifiConnectedMillis = millis();
        Serial.print("Connected with IP: ");
        Serial.println("Connection timed out");
      if (!timeSynched && millis() - previousTimeSync > 3000)
        previousTimeSync = millis();
        configTime(8 * 3600, 0, "pool.ntp.org");
      if (!timeSynched)
        timeSynched = getLocalTime(&timeinfo);
    if (Firebase.ready())
      uid = auth.token.uid.c_str();
      Serial.print("UID: ");
      Serial.println(uid);
      databasePath = "/userdata/" + uid + "/readings";
      time_t now;
      if (!getLocalTime(&timeinfo))
        Serial.println("Failed to obtain time");
        continue;
      time(&now);
      timestamp = now;
      Serial.printf("Time: %s", asctime(&timeinfo));
      parentPath = databasePath + "/" + String(timestamp);
      json.clear(); // Clear all elements
      json.add("t", "TEST");
      json.add("h", "TEST");
      json.add("p", "TEST");
      json.add("f", "TEST");
      json.add("ts", String(timestamp));
      delay(0);
      Serial.printf("Set json... %s\n", Firebase.RTDB.setJSON(&fbdo, parentPath.c_str(), &json) ? "ok" : fbdo.errorReason().c_str());
    vTaskDelay(2000 / portTICK_PERIOD_MS);
  WiFi.mode(WIFI_STA);
  config.api_key = API_KEY;
  auth.user.email = USER_EMAIL;
  auth.user.password = USER_PASSWORD;
  config.database_url = DATABASE_URL;
  fbdo.setResponseSize(4096);
  config.token_status_callback = tokenStatusCallback;
  Firebase.begin(&config, &auth);
  xTaskCreatePinnedToCore(
    wifi,
    "WiFi",
    10240,
    NULL,
    1,
    NULL,
    0
The WDT reset error that I keep on receiving is like this:
The following tasks did not reset the watchdog in time:
E (60250) task_wdt:  - IDLE (CPU 0)
E (60250) task_wdt: Tasks currently running:
E (60250) task_wdt: CPU 0: WiFi
E (60250) task_wdt: CPU 1: loopTask
E (60250) task_wdt: Aborting.
abort() was called at PC 0x400f904c on core 0
Backtrace:0x40083611:0x3ffbea4c |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:12812
load:0x40080400,len:3032
entry 0x400805e4
I installed Arduino IDE and the ESP Exception Decoder and pasted that error, this is what shows up:
Decoding stack results
0x40083611: panic_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/panic.c line 402
However, there is also some chance that I received this error when I disconnect Wi-Fi during the vTaskDelay() period of 2 secs.
[ 60374][E][ssl_client.cpp:36] _handle_error(): [data_to_read():343]: (-76) UNKNOWN ERROR CODE (004C)
Set json... response payload read timed out due to network issue or too large data size
I am using:
  • ESP32 NodeMCU-32S
  • Firebase Client
  • PlatformIO IDE v2.4.3 using Arduino Framework
  • I also have Arduino IDE 1.8.19 installed with ESP Exception Decoder
Help is very much appreciated. Thank you!
The Arduino core for the ESP32 automatically configures FreeRTOS so that core_0 is the RF-ESP-protocol and core_1 is Arduino. As configured, you should use loop() because yield() IS automatically added. If more core_0 time is required, you can experiment with adding extra yield() or delay(0) as needed. Google for difference.
I already found a solution/workaround to this problem. I fixed it by removing the config.token_status_callback = tokenStatusCallback; in the void setup() {}.
