crawling quadruped robot will not upload
I accidentally uploaded the transmit.ino to the servo control board and the remote and when I try to load receive.ino it shows this.
Sketch uses 3452 bytes(11%)of program storage space. Maximum is 30720 bytes.
Global variables use 273 bytes (13%) of dynamic memort, leaving 17775 bytes for local variables. Maximum is 2048 bytes.
Invalid library found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt: no headers (.h) found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt
Then when I try to look at the serial monitor (the next step) it says no radio available. and the transmit light stays on (the green one)
help would be very nice.
this uses a sunfounder nano board. this is the receive code
  • File: nRF24l01 Receive Test
  • Copyright: Copyright (C) 2015 SunFounder. For details, check License folder.
  • Date: 2015/7/21
  • Overview
  • This project was written to test nRF24l01 module. If it runs, arduino will
    receives data from another transceiver with 2 Analog values from a Joystick
    or 2 Potentiometers Displays received values on Serial Monitor.
  • Request
  • RF24 library
  • Connections
  • nRF24L01 to Arduino
    1 GND GND
    2 VCC 3V3
    3 CE D9
    4 CSN D10
    5 SCK D13
    6 MOSI D11
    7 MISO D12
    8 UNUSED
/* Includes ------------------------------------------------------------------/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
Ports ---------------------------------------------------------------------/
#define CE_PIN 9
#define CSN_PIN 10
nRF24l01 ------------------------------------------------------------------/
// NOTE: the “LL” at the end of the constant is “LongLong” type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
Joystick ------------------------------------------------------------------/
int joystick[2]; // 2 element array holding Joystick readings
  • setup function
    Serial.println(“nRF24l01 Receiver Starting”);
    radio.begin();
    radio.setRetries(0, 15);
    radio.setPALevel(RF24_PA_HIGH);
    radio.openReadingPipe(1,pipe);
    radio.startListening();;
  • loop function
    if ( radio.available() )
    Serial.println(“serial”);
    // Read the data payload until we’ve received everything
    bool done = false;
    while (!done)
    // Fetch the data payload
    done = radio.read( joystick, sizeof(joystick) );
    Serial.print("X = “);
    Serial.print(joystick[0]);
    Serial.print(” Y = ");
    Serial.println(joystick[1]);
    Serial.println(“No radio available”);
MarshallRohrbach: when I try to load receive.ino it shows this.
Sketch uses 3452 bytes(11%)of program storage space. Maximum is 30720 bytes. Global variables use 273 bytes (13%) of dynamic memort, leaving 17775 bytes for local variables. Maximum is 2048 bytes. Invalid library found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt: no headers (.h) found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt Invalid library found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt: no headers (.h) found in C:\Users\Marshall\Documents\Arduino\libraries\readme.txt
That output doesn't indicate any problem at all. Did the IDE show a message that the upload failed?
I've deleted your other cross-post @MarshallRohrbach.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
it said it worked but nothing happened
Sorry I didn't realize that was a problem.
