My friends call this project “crazy” and I think
this is the best name for it.
I discussed parts of it in my previous topic and I want to thank
people who came with suggestions.
http://arduino.cc/forum/index.php/topic,153845.0.html
My project includes an Arduino Mega, 12 LEDs and a 4/3 keypad.
I want to use the keypad to control the binary counting on LEDs.
This is my code so far:
/* Binary counting using 12 LEDs and a keypad to control
the increasing or decreasing rate by the value
of the key pressed*/
#include <Keypad.h>
int ledPin[12]={13,12,11,10,9,8,7,6,5,4,3,2};
int number=0;
int keyPressed=0;
int counter=0;
char firstKey;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {31, 33, 35, 37}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {39, 41, 43}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
for(counter=0; counter<12; counter++)
pinMode(ledPin[counter], OUTPUT); // sets the digital pins as output
void loop(){
char key = customKeypad.getKey();
/*if (key) {
Serial.println(key);
if (key) { // blocking from anything not needed
keyPressed= keyPressed+1;
if (key != '*' && key !='#'){
number =key - '0' ; // convert key to its value
} // end of sort
if (keyPressed ==1){
firstKey=key;
if ( keyPressed==2){
Serial.println(firstKey);
//Serial.println(number);
if (key == '#') // increment binary counter
Serial.println("i"+firstKey);
//digitalWrite(13, HIGH);
//delay (1000);
for(counter=0; counter< number; counter++){
//digitalWrite(ledPin[counter-1], HIGH);
digitalWrite(ledPin[counter], HIGH);
delay (1000);
} // end of increment counter
} // end of '#'
if (key == '*') // decrement binary counter
for(counter; counter < number; counter-- ){
if (counter < 0) counter = 0; // checks to see if
// counter does past zero then set it back to zero
digitalWrite(ledPin[counter], LOW);
delay (1000);
} // end of decrement counter
} // end of '*'
keyPressed=0;
} // end of keycount
} //end of if(key)
} // end of loop
The schetch works but the counting still does’t work as I want.
There are a few things left to do:
Convert to binary counting
Get two number keys and an operator key at the time
By getting two number keys at the time I can increase the combinations
up to 99. Since 12 bits in binary gives the value 4096 in decimal, there is enough
room to play with number combinations and convert them to binary.
At the moment my keypad only reads two keys at the time but it behaves strangely
and I can see in the Serial Monitor that it has moments when reading the keys or not.
As I said, I want to read two number keys and an operator (either ‘*’ or ‘#’ meaning
counting up or down) at any time and perhaps to start from zero at any new counting.
Waiting for your suggestions.
Regards
