CRC-8, I2C Cyclic redundancy check
Hello all,
I'm using a I2C device that also works with CRC error detection. I wish to implement it but I don't know how.
The manufacturer says: "The every I2C byte are calculated using CRC8 algorithms. The CRC polynomial is following: x8 + x5 + x3 + x2 + x + 1." I know that this is equal to 100101111.
Also the manufacturer says an example when we send data to the device with the CRC enabled: Data:0xC0 0xC0 0x00 0xCF 0xFF, followed by the CRC: 0x2E.
So, the thing is: how could I calculate this 0x2E in my code?
Reading in the internet I found this function:
//CRC-8 - based on the CRC8 formulas by Dallas/Maxim
//code released under the therms of the GNU GPL 3.0 license
byte CRC8(const byte *data, size_t dataLength)
  byte crc = 0x00;
  while (dataLength--)
    byte extract = *data++;
    for (byte tempI = 8; tempI; tempI--)
      byte sum = (crc ^ extract) & 0x01;
      crc >>= 1;
      if (sum)
        crc ^= 0x8C;
      extract >>= 1;
  return crc;
But this code don't ask the the CRC polynomial. help please :frowning:
Thanks in advance!
Does the identity of this device have to remain a secret?
It is the NCV7685, I know that because of his similar question here: https://forum.arduino.cc/index.php?topic=669132.0.
@ammc Please be clear if you asked the question before or even on another forum.
I think the documentation may be off. This code produces the desired answer
const byte data[] = { 0xC0, 0xC0, 0x00, 0xFF, 0xCF };
  Serial.println("Ready");
  byte crc = Compute_CRC8(data, sizeof(data));
  Serial.print("CRC =");
  Serial.println(crc, HEX);
byte Compute_CRC8(byte *bytes, int len) {
  const byte generator = B00101111;   // polynomial = x^8 + x^5 + x^3 + x^2 + x + 1 (ignore MSB which is always 1)
  byte crc = 0;
  while (len--)
    crc ^= *bytes++; /* XOR-in the next input byte */
    for (int i = 0; i < 8; i++)
      if ((crc & 0x80) != 0)
        crc = (byte)((crc << 1) ^ generator);
        crc <<= 1;
  return crc;
but you will notice that the value (0xCFFF) is computed with LSB first, not MSB first
You can also use a lookup table for faster runtime execution. I'm getting the same results as blh64 using this code that uses a lookup table.
