I need to calculate CRC on stm32f4 series MCU, luckily this family has HW for it. It is very simple, only 1 data register and then only one bite in next register for reset. Check it if you want at CRC section in datasheet, it is starting at page 66 and it is very short text. datasheet
So I firstly enabled clock for CRC unit and reset it:
__HAL_RCC_CRC_CLK_ENABLE();
CRC->CR |= 1;
Then I filled data register and read it back, because CRC value is stored there after conversion:
and the result was correct, you can verify it on https://crccalc.com/ if you use hex value 000000C1 and look at the result under CRC-32/MPEG-2 protocol. But if I fill DR register like this:
The CRC registers are 32 bits long so when you only fill it with an 8/16 bit value the results are not going to be what you expect.
See if it works correctly with...
This simple detection mechanism works if an odd number of bits in a byte changes, but The CRC calculation or cyclic redundancy check was the result of this.The theory of a CRC calculation is straightforward. The data is treated by the CRC algorithm as a binary number. This number is divided by another binary number called the polynomial. The rest of the division is the CRC checksum, which is appended to the transmitted message. NomNom
It seems like the register will expand any given value to fit the entire register by repeating it. Accessing the register as 8-bit will cause the register to filled with four times 8-bit (eg. 0xC1 becomes 0xC1C1C1C1) and when accessing it as 16-bit it will be filled with two 16-bit values (eg. 0xC1 becomes 0x00C100C1).
First of all, that register is not meant be used that way. It is a 32-bit register. Since the stm32f4 is 32-bit microcontroller I suspect when you try to do an 8-bit write the byte is reflected on each 8 bits of the internal data bus of the processor. Similarly when you try to do a 16-bit write. I'm sure the chip designers didn't worry about it since it shouldn't be used that way.
