CRC16 help to find polynom for algoritm
Good evening!
I am using arduino uno to read data from industrial refrigerator (using RS232).
I`m getting message from reefer like this in hex: "3000EF000500000C00120188FAAB40"
Last two bytes is CRC16, I can detect it by online decoders, for example: http://www.lammertbies.nl/comm/info/crc-calculation.html , it writes that it is simple CRC16 alghoritm.
So, Ive tried such code, but cant get exact result:
#define POLYNOM		0x8005   // Define the used polynom from one of the aboves
unsigned int crc16(unsigned int crcValue, unsigned char newByte)
	unsigned char i;
	for (i = 0; i < 8; i++) {
		if (((crcValue & 0x8000) >> 8) ^ (newByte & 0x80)){
			crcValue = (crcValue << 1)  ^ POLYNOM;
		}else{
			crcValue = (crcValue << 1);
		newByte <<= 1;
	return crcValue;
/***** EXAMPLE *****/
unsigned int exampleOfUseCRC16 (unsigned char *Data, unsigned char len){
	unsigned int crc;
	unsigned char aux = 0;
	crc = 0x0000; //Initialization of crc to 0x0000 for DNP
	//crc = 0xFFFF; //Initialization of crc to 0xFFFF for CCITT
	while (aux < len){
		crc = crc16(crc,Data[aux]);
		aux++;
	return (~crc); //The crc value for DNP it is obtained by NOT operation
	//return crc; //The crc value for CCITT
 //byte buf[]={0x30,0x00,0xEF,0x00,0x05,0x00,0x00,0x0C,0x00,0x12,0x01,0x18,0xFC};
  byte buf[]={0x30,0x00,0xEF,0x00,0x05,0x00,0x0,0x0C,0x00,0x12,0x01,0x88,0xFA};//,0xAB,0x40};crc16
void setup(){
 Serial.println( exampleOfUseCRC16(buf,13),HEX);
void loop(){}
Code returns 0AC9, not AB40
I tried a lot of other polynoms, but result still not like in original system.
Please, someone has idea about how make the same CRC16 from message like refrigerator has?
I get CRC-16 checksum of 0x40AB
It may be that they are sending the MSB first.
If you have another hex string to try, you will know.
ieee488:
Yes, indeed.
Simply use the AVR LIBC function named '_crc16_update()' to create the CRC:
#include <util/crc16.h>
void setup(){
  uint16_t crc=0;
  for(int i=0;i<13;i++) crc= _crc16_update(crc,buf[i]);
  Serial.println(crc,HEX);
void loop(){
