Creat a Library
I 'm having a lot of problems with GPS module 7M, it looses the setup after 2/3 hous disconnected ( probably battery fail). I whant to make a library to set um the module every time you start the program, the codes to make de setup are below, I try to make a library but doens't work, if somebody can helpme will be great.
  • The sketch restores the receiver default configuration and configure it to get NAV-PVT messages with 100 ms
  • frequency and 115200 baudrate. After the auto-configuration, it transmits the data from the receiver to the PC and
  • vice versa.
  • u-blox NEO-7M - Arduino Mega
  • VCC - 5V
  • RX - TX3
  • TX - RX3
  • GND - GND
#include <Arduino.h>
#define PC_SERIAL Serial
#define PC_BAUDRATE 9600L
#define GPS_SERIAL Serial3
// Default baudrate is determined by the receiver manufacturer.
#define GPS_DEFAULT_BAUDRATE 9600L
// Wanted baudrate at the moment can be 9600L (not changed after defaults) or 9600L (changed by the
// changeBaudrate() function with a prepared message).
#define GPS_WANTED_BAUDRATE 9600L
// Array of possible baudrates that can be used by the receiver, sorted descending to prevent excess Serial flush/begin
// after restoring defaults. You can uncomment values that can be used by your receiver before the auto-configuration.
const long possibleBaudrates[] = {
9600L,
PC_SERIAL.begin(PC_BAUDRATE);
PC_SERIAL.println("Starting auto-configuration...");
// Restore the receiver default configuration.
for (byte i = 0; i < sizeof(possibleBaudrates) / sizeof(*possibleBaudrates); i++)
    PC_SERIAL.print("Trying to restore defaults at ");
    PC_SERIAL.print(possibleBaudrates[i]);
    PC_SERIAL.println(" baudrate...");
    if (i != 0)
        delay(100); // Little delay before flushing.
        GPS_SERIAL.flush();
    GPS_SERIAL.begin(possibleBaudrates[i]);
    restoreDefaults();
// Switch the receiver serial to the default baudrate.
if (possibleBaudrates[sizeof(possibleBaudrates) / sizeof(*possibleBaudrates) - 1] != GPS_DEFAULT_BAUDRATE)
    PC_SERIAL.print("Switching to the default baudrate which is ");
    PC_SERIAL.print(GPS_DEFAULT_BAUDRATE);
    PC_SERIAL.println("...");
    GPS_SERIAL.flush();
    GPS_SERIAL.begin(GPS_DEFAULT_BAUDRATE);
// Disable NMEA messages by sending appropriate packets.
PC_SERIAL.println("Disabling NMEA messages...");
disableNmea();
// Switch the receiver serial to the wanted baudrate.
if (GPS_WANTED_BAUDRATE != GPS_DEFAULT_BAUDRATE)
    PC_SERIAL.print("Switching receiver to the wanted baudrate which is ");
    PC_SERIAL.print(GPS_WANTED_BAUDRATE);
    changeBaudrate();
    GPS_SERIAL.flush();
    GPS_SERIAL.begin(GPS_WANTED_BAUDRATE);
// Increase frequency to 100 ms.
PC_SERIAL.println("Changing receiving frequency to 100 ms...");
changeFrequency();
// Disable unnecessary channels like SBAS or QZSS.
PC_SERIAL.println("Disabling unnecessary channels...");
disableUnnecessaryChannels();
// Enable NAV-PVT messages.
PC_SERIAL.println("Enabling NAV-PVT messages...");
enableNavPvt();
PC_SERIAL.println("Auto-configuration is complete!");
GPS_SERIAL.flush();
// Send a packet to the receiver to restore default configuration.
void restoreDefaults()
// CFG-CFG packet.
byte packet[] = {
0xB5, // sync char 1
0x62, // sync char 2
0x06, // class
0x09, // id
0x0D, // length
0x00, // length
0xFF, // payload
0xFF, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0xFF, // payload
0xFF, // payload
0x00, // payload
0x00, // payload
0x17, // payload
0x2F, // CK_A
0xAE, // CK_B
sendPacket(packet, sizeof(packet));
// Send a set of packets to the receiver to disable NMEA messages.
void disableNmea()
// Array of two bytes for CFG-MSG packets payload.
byte messages[][2] = {
{0xF0, 0x0A},
{0xF0, 0x09},
{0xF0, 0x00},
{0xF0, 0x01},
{0xF0, 0x0D},
{0xF0, 0x06},
{0xF0, 0x02},
{0xF0, 0x07},
{0xF0, 0x03},
{0xF0, 0x04},
{0xF0, 0x0E},
{0xF0, 0x0F},
{0xF0, 0x05},
{0xF0, 0x08},
{0xF1, 0x00},
{0xF1, 0x01},
{0xF1, 0x03},
{0xF1, 0x04},
{0xF1, 0x05},
{0xF1, 0x06},
// CFG-MSG packet buffer.
byte packet[] = {
    0x06, // class
    0x01, // id
    0x03, // length
    0x00, // length
    0x00, // payload (first byte from messages array element)
    0x00, // payload (second byte from messages array element)
    0x00, // payload (not changed in the case)
    0x00, // CK_A
    0x00, // CK_B
byte packetSize = sizeof(packet);
// Offset to the place where payload starts.
byte payloadOffset = 6;
// Iterate over the messages array.
for (byte i = 0; i < sizeof(messages) / sizeof(*messages); i++)
    // Copy two bytes of payload to the packet buffer.
    for (byte j = 0; j < sizeof(*messages); j++)
        packet[payloadOffset + j] = messages[i][j];
    // Set checksum bytes to the null.
    packet[packetSize - 2] = 0x00;
    packet[packetSize - 1] = 0x00;
    // Calculate checksum over the packet buffer excluding sync (first two) and checksum chars (last two).
    for (byte j = 0; j < packetSize - 4; j++)
        packet[packetSize - 2] += packet[2 + j];
        packet[packetSize - 1] += packet[packetSize - 2];
    sendPacket(packet, packetSize);
// Send a packet to the receiver to change baudrate to 115200.
void changeBaudrate()
// CFG-PRT packet.
byte packet[] = {
0x06, // class
0x00, // id
0x14, // length
0x00, // length
0x01, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0xD0, // payload
0x08, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0xC2, // payload
0x01, // payload
0x00, // payload
0x07, // payload
0x00, // payload
0x03, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0x00, // payload
0xC0, // CK_A
0x7E, // CK_B
// Send a packet to the receiver to change frequency to 100 ms.
void changeFrequency()
// CFG-RATE packet.
byte packet[] = {
0x06, // class
0x08, // id
0x06, // length
0x00, // length
0x64, // payload
0x00, // payload
0x01, // payload
0x00, // payload
0x01, // payload
0x00, // payload
0x7A, // CK_A
0x12, // CK_B
// Send a packet to the receiver to disable unnecessary channels.
void disableUnnecessaryChannels()
// CFG-GNSS packet.
byte packet[] = {
0x06, // class
0x3E, // id
0x24, // length
0x00, // length
    0x00, 0x00, 0x16, 0x04, 0x00, 0x04, 0xFF, 0x00, // payload
    0x01, 0x00, 0x00, 0x01, 0x01, 0x01, 0x03, 0x00, // payload
    0x00, 0x00, 0x00, 0x01, 0x05, 0x00, 0x03, 0x00, // payload
    0x00, 0x00, 0x00, 0x01, 0x06, 0x08, 0xFF, 0x00, // payload
    0x00, 0x00, 0x00, 0x01,                         // payload
    0xA4, // CK_A
    0x25, // CK_B
// Send a packet to the receiver to enable NAV-PVT messages.
void enableNavPvt()
// CFG-MSG packet.
byte packet[] = {
0x06, // class
0x01, // id
0x03, // length
0x00, // length
0x01, // payload
0x07, // payload
0x01, // payload
0x13, // CK_A
0x51, // CK_B
// Send the packet specified to the receiver.
void sendPacket(byte *packet, byte len)
for (byte i = 0; i < len; i++)
GPS_SERIAL.write(packet[i]);
printPacket(packet, len);
// Print the packet specified to the PC serial in a hexadecimal form.
void printPacket(byte *packet, byte len)
char temp[3];
    sprintf(temp, "%.2X", packet[i]);
    PC_SERIAL.print(temp);
    if (i != len - 1)
        PC_SERIAL.print(' ');
PC_SERIAL.println();
// If there is a data from the receiver, read it and send to the PC or vice versa.
if (GPS_SERIAL.available())
PC_SERIAL.write(GPS_SERIAL.read());
if (PC_SERIAL.available())
    GPS_SERIAL.write(PC_SERIAL.read());
What does that mean?
Please remember to use code tags when posting code
Auto-configuration-Mega
enable , disable and set all the parametes I need to use the GPS module 7M
Sounds a familiar request;
