Hi everyone
I bought myselve the Nokia 3310 shield for Arduino and tried out some examples. Everything worked fine but now I want to modify the code below a little bit.
#include "nokia_3310_lcd.h"
#include "avr_bmp.h"
//keypad debounce parameter
#define DEBOUNCE_MAX 15
#define DEBOUNCE_ON 10
#define DEBOUNCE_OFF 3
#define NUM_KEYS 5
#define NUM_MENU_ITEM 4
// joystick number
#define UP_KEY 3
#define LEFT_KEY 0
#define CENTER_KEY 1
#define DOWN_KEY 2
#define RIGHT_KEY 4
// menu starting points
#define MENU_X 10 // 0-83
#define MENU_Y 1 // 0-5
// adc preset value, represent top value,incl. noise & margin,that the adc reads, when a key is pressed
// set noise & margin = 30 (0.15V@5V)
int adc_key_val[5] ={30, 150, 360, 535, 760 };
int sec;
int minute;
// debounce counters
byte button_count[NUM_KEYS];
// button status - pressed/released
byte button_status[NUM_KEYS];
// button on flags for user program
byte button_flag[NUM_KEYS];
// menu definition
char menu_items[NUM_MENU_ITEM][12]={
"TEMPERATURE",
"CHAR MAP",
"DEMO",
"ABOUT"
void (*menu_funcs[NUM_MENU_ITEM])(void) = {
clock,
charmap,
bitmap,
about
char current_menu_item;
Nokia_3310_lcd lcd=Nokia_3310_lcd();
// setup interrupt-driven keypad arrays
// reset button arrays
for(byte i=0; i<NUM_KEYS; i++){
button_count[i]=0;
button_status[i]=0;
button_flag[i]=0;
// Setup timer2 -- Prescaler/256
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
TCCR2B = (1<<CS22)|(1<<CS21);
ASSR |=(0<<AS2);
// Use normal mode
TCCR2A =0;
//Timer2 Overflow Interrupt Enable
TIMSK2 |= (0<<OCIE2A);
TCNT2=0x6; // counting starts from 6;
TIMSK2 = (1<<TOIE2);
SREG|=1<<SREG_I;
lcd.LCD_3310_init();
lcd.LCD_3310_clear();
//menu initialization
init_MENU();
current_menu_item = 0;
/* loop */
byte i;
for(i=0; i<NUM_KEYS; i++){
if(button_flag[i] !=0){
button_flag[i]=0; // reset button flag
switch(i){
case UP_KEY:
// current item to normal display
lcd.LCD_3310_write_string(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_NORMAL );
current_menu_item -=1;
if(current_menu_item <0) current_menu_item = NUM_MENU_ITEM -1;
// next item to highlight display
lcd.LCD_3310_write_string(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_HIGHLIGHT );
case DOWN_KEY:
current_menu_item +=1;
if(current_menu_item >(NUM_MENU_ITEM-1)) current_menu_item = 0;
case LEFT_KEY:
init_MENU();
case RIGHT_KEY:
(*menu_funcs[current_menu_item])();
init_MENU();
/* menu functions */
void init_MENU(void){
byte i;
lcd.LCD_3310_write_string(MENU_X, MENU_Y, menu_items[0], MENU_HIGHLIGHT );
for (i=1; i<NUM_MENU_ITEM; i++){
lcd.LCD_3310_write_string(MENU_X, MENU_Y+i, menu_items[i], MENU_NORMAL);
// waiting for center key press
void waitfor_OKkey(){
byte i;
byte key = 0xFF;
while (key!= CENTER_KEY){
if(i== CENTER_KEY) key=CENTER_KEY;
void clock()
lcd.LCD_3310_write_char_big(50, 1, sec, MENU_NORMAL);
sec+1;
if(sec==60);
minute+1;
waitfor_OKkey();
void charmap(){
char i,j;
for(i=0; i<5; i++){
for(j=0; j<14; j++){
lcd.LCD_3310_set_XY(j*6,i);
lcd.LCD_3310_write_char(i*14+j+32, MENU_NORMAL);
lcd.LCD_3310_write_string(38, 5, "OK", MENU_HIGHLIGHT );
waitfor_OKkey();
void bitmap(){
lcd.LCD_3310_draw_bmp_pixel(0,0, AND_bmp, 84,48);
delay(100);
lcd.LCD_3310_draw_bmp_pixel(15,1, AVR_bmp, 48,24);
delay(100);
lcd.LCD_3310_draw_bmp_pixel(0,1, PAC_bmp, 32,32);
lcd.LCD_3310_write_string(30, 2, ".", MENU_NORMAL);
lcd.LCD_3310_write_string(50, 2, "...", MENU_NORMAL);
waitfor_OKkey();
void about(){
lcd.LCD_3310_write_string(10, 2, "ARDUINO 101", MENU_NORMAL);
waitfor_OKkey();
// The followinging are interrupt-driven keypad reading functions
// which includes DEBOUNCE ON/OFF mechanism, and continuous pressing detection
// Convert ADC value to key number
char get_key(unsigned int input)
char k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)
k = -1; // No valid key pressed
return k;
void update_adc_key(){
int adc_key_in;
char key_in;
byte i;
adc_key_in = analogRead(0);
key_in = get_key(adc_key_in);
if(key_in==i) //one key is pressed
if(button_count[i]<DEBOUNCE_MAX)
button_count[i]++;
if(button_count[i]>DEBOUNCE_ON)
if(button_status[i] == 0)
button_flag[i] = 1;
button_status[i] = 1; //button debounced to 'pressed' status
else // no button pressed
if (button_count[i] >0)
button_flag[i] = 0;
button_count[i]--;
if(button_count[i]<DEBOUNCE_OFF){
button_status[i]=0; //button debounced to 'released' status
// Timer2 interrupt routine -
// 1/(160000000/256/(256-6)) = 4ms interval
ISR(TIMER2_OVF_vect) {
TCNT2 = 6;
update_adc_key();
I want to create a loop inside the function "void clock" to start a timer but I have no Idea how to do this. I tried it without theloop like the code below but it will just show a 0 and not the time.
void clock:
void clock()
sec+1;
if(sec==60);
minute+1;
waitfor_OKkey();
Hope you can help me? :~
