Create a simple audio amplifier with a MOSFET
Hi, I am pretty new to Arduino and I have that little speaker from Sparkfun (Thin Speaker - 0.5W - COM-15350 - SparkFun Electronics). It's pretty loud, but I want to make it sound louder.
I've read of many "simple" circuits, made with various transistors+resistors combinations, but I don't have (right now) some of the required materials, so I was wondering : can I make a sound amplifier with a MOSFET transistor like that one : MosfetTransistor.pdf (included in the Arduino starter pack)? I just need to amplify the square wave produced by the Arduino's tone() function.
Thanks in advance
You need 10 volts on the gate of that MOSFET to turn it on.
The Arduino outputs 5 volts.
Use a logic MOSFET ex: IRL540
No. Was it in the starter pack? It should not have been, it is not a logic level FET and so it will not turn on fully with 5V, it requires 10V.
You will get something but it will get a lot hotter than it otherwise would and it will not be as loud as it could be.
Loose the 47R resistor to make it louder. Make sure your power supply can give the current required.
I didn't want the OP to blow the Arduino up.
LarryD:
Thanks for the suggestion :slight_smile: !
Just one thing : the 47R stands for a resistor of 47 ohms? Seems a little weird to me....
Yes
The R is used for ohms as there is no Ω symbol on the keyboard.
Standard electronics notation:
0R12 = 0.12 ohms (120 milliohms)
3R3 = 3.3 ohms
33R = 33 ohms
3k3 = 3.3k ohms
2M2 = 2.2M ohms
The letter stands in for the decimal point because a printed '.' on a component is very easy to
miss (or be rubbed off / illegible).
Same goes for farads and henries, ie 2n7 on a cap is 2.7nF, 47m on an inductor would be 47m.
LarryD:
Heh, heh. ½µ°
Paul__B:
Heh, heh. ½µ°
+1
You passed the test :wink:
"Character Map" widget. Essential hotlink.
Paul__B:
"Character Map" would be better if it had a history of your recently used characters, just like Microsoft do in the Word/Excel "insert character" function.
