Create Agent unable to configure device
Hello,
I'm new with arduino and want to install the template on the nano rp2040 plant watering set from arduino. I failed on one computer (windows 10), maybe because of an interference with Avira Antivir. Now I also failed on a second computer running Windows 11 without Avira. It is always the same procedure: I reinstall the create agent, restart the arduino (which is without its board, only attached to the computer, all lights blinking), I click on the page "https://create.arduino.cc/iot/templates/plant-watering-kit" on "import template". It finds the device and says: "Arduino Nano RP2040 Connect found // An Arduino Nano RP2040 Connect has been detected on port COM4 and ready to be configured." I click on "configue" and a page appears, where I should give the device a name. A windows message appears saying, that a device has been found and imediately after that, a message appears saying " We were not able to configure your device. Executing command: exit status 1". None of the recommandations was able to fix this problem. What should I do?
Hopefully someone knows what to do.
Dirk
Can you try again? there was an issue with the Arduino create agent that was only fixed recently.
