Create array integer data from digital inputs
I am working on a project to convert a 1960's rotor telephone to a gsm phone. The first part of the project has me counting switches. My code currently counts the number of pulses, looks for another switch that activates when the rotor has finished turning, and returns the count value to the serial terminal.
This works fine (and is located at the very bottom). However, I would like to take these count values and load them into an array so I can send the full 10 digit number as an array over to my gsm shield (second if statement form the bottom). I have tried every way I know how but the return seems to always be the first count value assigned to all 10 array locations. Any help would be appreciated.
// this constant won't change:
const int  buttonPin = 2;    // the pin that the rotary number switch is attached to
const int diallingPin = 4; // pin that the rotor start/finish is attached to
// Variables that will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 1;     // previous state of the button
int phoneNumber[9];          // sets array for phone number
int dialing = 0;            // sets state of dialing on/off
int dialState;             // place to store dial state
int numberString;           // keep track of the numbers dialer
int number = 0;
int array [10];
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initializes dialling pin as an input;
  pinMode(diallingPin, INPUT);
  // initialize serial communication:
    Serial.println("Setup is initialized");
    Serial.print("Current state of Dial Connector is  ");
    if(digitalRead(2) == 1){
      Serial.println("on");
      }else{
      Serial.println("off");
    Serial.print("Current state of Dialer is  ");
    if(digitalRead(4) == 1){
      Serial.println("dialing");
      }else{
      Serial.println("base");
  // read the pushbutton input pin:
  buttonState = digitalRead(2);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // went from off to on:
      buttonPushCounter++;
      //Serial.println("on");
      //Serial.print("number of button pushes:  ");
      //Serial.println(buttonPushCounter);
      // if the current state is LOW then the button
      // went from on to off:
      //Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  if(buttonPushCounter > 0 && digitalRead(4) != 1){
     for(number = 0; number <= 9; number++){
         array[number] = buttonPushCounter;
         Serial.println(array[number]);
 // if(buttonPushCounter > 0 && digitalRead(4) != 1){
   // Serial.print(buttonPushCounter);
   // buttonPushCounter = 0;
  if (buttonPushCounter > 0 && digitalRead(4) != 1) {
    for (number = 0; number <= 9; number++) {
This is putting the same number in each element of the array. Don't you just need to do
 number++;  //ready for the next number to be stored
where number is a variable set to zero before dialling
