Create binary 'string' of digital pin status
So I'm trying to interface with a piece of wireless equipment that accepts an input that appears as a binary number but is really just the status of 8 relays. For example, 00000001 would indicate that the first relay is on and the other 7 relays are off.
What I'm trying to do is read the status of digital pins 2 through 9, arrange them per that format and write them to my wifi module as one binary byte.
This has been my approach so far:
Read the digital pins through either digitalRead() or PINB/PIND
Convert to string
Modify the strings and combine them in the order I want
Convert back to binary
Send via Serial.write()
This is one of my recent versions that seemed to almost work...
String relay1 = String(digitalRead(2));
String relay2 = String(digitalRead(3));
String relay3 = String(digitalRead(4));
String relay4 = String(digitalRead(5));
String relay5 = String(digitalRead(6));
String relay6 = String(digitalRead(7));
String relay7 = String(digitalRead(8));
String relay8 = String(digitalRead(9));
String relaystatestring = String(relay1 + relay2 + relay3 + relay4 + relay5 + relay6 + relay7 + relay8);
relaystate = byte(relaystatestring.toInt());
Serial.write(relaystate);
bitRead()
bitWrite()
Maybe something like this... (untested and UNO only)
byte relaystate = (PINB << 6) | (PIND >>2);
untested
for(int n=2; n<10; n++ )
  pinMode(n,INPUT);
unsigned long lastReport=0;
unsigned long t=millis();
byte x=0;
//give a printOut every second
if ( (t-lastReport) >= 1000 )
  for (int n=0; n<8; n++)
    if(digitalRead(2+n) == HIGH)
       x |= 1<<n;
  //print result and note when we showed it
  Serial.println(x ,DEC);
  lastReport=t;
Riva, thanks for the tip! Very elegant solution.
And thanks everybody else! Great info from all.
