Create byte to send to MCP23017 from boolean tests
I need to send a byte to an MCP23017 to activate a series of relays based upon the results of some boolean tests that compare input conditions from other inputs. How does one efficiently create a byte from these boolean tests
e.g. True, False, False, False, False, False, True, False >> 10000010
Thanks, Jeff
This is a tad clunky, but it’s the first thing that came to mind:
#define BIT8  7
#define BIT7  6
#define BIT6  5
#define BIT5  4
#define BIT4  3
#define BIT3  2
#define BIT2  1
#define BIT1  0
byte byteToSend;
  int testVal;
  byteToSend = 0;
  PackByte(BIT4, true);       // Send: 00001010 (= 10 DEC)
  PackByte(BIT2, true);
  Serial.println(byteToSend);
void PackByte(int whichBit, int whichState)
  byteToSend |= whichState << whichBit;
Making use of bitfields is an options
struct BITS
  byte b1: 1;
  byte b2: 1;
  byte b3: 1;
  byte b4: 1;
  byte b5: 1;
  byte b6: 1;
  byte b7: 1;
  byte b8: 1;
  union
    BITS logic;
    byte value;
  } bits;
  bits.logic.b1 = false;
  bits.logic.b2 = true;
  bits.logic.b3 = false;
  bits.logic.b4 = false;
  bits.logic.b5 = false;
  bits.logic.b6 = false;
  bits.logic.b7 = false;
  bits.logic.b8 = true;
  Serial.println(bits.value, HEX);
You can directly set the bits in the struct from your logic. The union allows access to either the bit form or the byte form.
econjack:
This only works for true. It won’t strike a bit with false.
Because true OR false = true.
To make it work for both true and false, do this:
  if (whichState)
    byteToSend |= 1 << whichBit;
    byteToSend &= ~(1 << whichBit);
Because true AND NOT true is false.
@Jobi-Wan: You are correct.
Thank you all, I will poke around with these and see what happens.
