I am trying to make a field that narrow and about 30ft long.
so I need to get a distance of a certain range (30ft aprox.)
it doesn't has to be precisely accurate, but I would like to generate at least 5 to 10 steps, so I can set the range.
not the way of IR cam above the field right now..
I was going to use distance range sensor, but it seems works better with close distance. Any ideas to make 30th long range with sensors?
When you posted this I thought "Would the frequency antenna of a Theremin work if 30ft long?" and "How far from this wire would you be able to detect a person or object?"
