Create HTTP Connection with ethernet shield Arduino Uno
I am trying to connect server using server IP and port ,But when execute client.connect(server, 80) function then it return 0...
So please any one help me
Ethernet shield model : W5100
Arduino Uno
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 172, 16, 0, 35 };
byte server[] = { 172, 16, 0, 22 }; // other available IP system in lan
EthernetClient client;
Ethernet.begin(mac, ip);
Serial.println("connecting...");
int clientStatus =client.connect(server, 80)
Serial.println("ClientStatus :");
Serial.println(clientStatus);
if (clientStatus == 1) {
Serial.println("connected");
client.println("GET /webApi/values HTTP/1.1");
client.println(Host: 172.16.0.22);
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
for(;:wink:
the WebClient example of the latest version 2.00 of the Ethernet library does work?
Juraj:
Yes working but not connect to server..
Serial Monitor Response as shown below
Initialize Ethernet with DHCP:
Failed to configure Ethernet using DHCP
connecting to 172.16.0.32...
connection failed
disconnecting.
Received 0 bytes in 0.0000, rate = 0.00 kbytes/second
did you connect the ethernet cable to a router or switch? because a connection to computer is not so simple
Is your computer/router acting as a DHCP server?
Juraj:
We are using Switch
if you have an SD card inserted in the shield, remove it
PaulS:
thank you for giving response
We are not using DHCP server, only used static IP
But when we create DHCP server using Router then it retuns success
