Create MQTT Broker online in the browser?
Hey,
Iam doing project where a ESP8266 microcontroller sends temperature and humidity via MQTT to a PC. Thats the plan. But I need a broker for MQTT. Right?
Does anybody knows a provider where I can create or use a broker online? Like a web interface. I cant install a program local. So the broker cant run local.
I did some research, but I found only options with costs. I want a free 1.
Thnaks for you attention and help.
Can you explain this project in more detail, you say the data is for a PC but you cannot run a local MQTT broker.
Does this mean you are happy to miss messages when the PC is not powered or do you expect to retain messages somehow.
I have used several free online services over the years but most of them did not use MQTT and eventually started a pricing plan so I resorted to using a Raspberry Pi Zero W to run my own local MQTT broker and it stored and graphed the readings to a web interface for me. All totally free apart from the initial cost of the Zero, SD card and power usage.
You can download and install MQTT Broker to your PC for FREE!!!!!!!
Idahowalker:
"I cant install a program local. So the broker cant run local "
SQUEEEE!!! "broker.emqx.io" is a free MQTT BROKER!
I figure you did not enter searches like "adafruit mqtt broker"
I figure you did not try to use the public Eclipse MQTT broker?
I figure you did not try to use the AWS MQTT Broker, free for one year?
Heck, even Arduino has a MQTT broker out there somewhere for the public to use.
The list is quite long of free public MQTT brokers.
