can some one point me to the right direction
i like to make a UI with some buttons and fader (realy easy)
but i like to create Sequences with the UI.
as example a drum pad. where i can press a button CREATE SEQUENCE. i can add Steps and on each step i press a button(tone). after that i can save the Sequence to a other button and if i press the button it will play it back.
Investigate the PC program Processing. It can easily interface to Arduno and uses a similar syntax style.
Processing
seems nice i will look at this.
Not without understanding where you want to make this UI, and how you expect it to communicate with the Arduino.
i just like to make the UI with buttons and fader or encoders connected to the arduino.
so a stand alone (ONLY) arduino based. NO pc or other stuff in between.
and to give a idea.
i like to store 20x20 = 400 Sequences (but less for the beginning) but i dont know yet how long a Sequence can be.(as i dont know what the limit are)
and the value i like to store are value’s between 0 and 255.
But i can only playback 20 Sequences at the time.
if a SD card could be used is no problem.
