Create web server with uno and ESP8266
I want to create an web server with Arduino uno and ESP8266.
Here is my code:
#include <SoftwareSerial.h>
const byte rxPin = 2;
const byte txPin = 3;
SoftwareSerial ESP8266 (rxPin, txPin);
unsigned long lastTimeMillis = 0;
int triedTime = 0;
  ESP8266.begin(115200);
  //ESP8266.begin(2000000);
  triedTime = 0;
  createServer();
  Serial.println("");
  Serial.println("Server is Ready");
  Serial.println("");
void createServer(){
  ESP8266.println("AT+CWSAP=\"Rmt\",\"1234test\",5,3");
  ESP8266.println("AT+CIPMUX=1");
  ESP8266.println("AT+CIPSERVER=1,80");
void printResponse() {
  while (ESP8266.available()) {
    Serial.println(ESP8266.readStringUntil('\n'));
    if ( Serial.available() )
     int connectionId = ESP8266.read()-48; // subtract 48 because the read() function returns
                                           // the ASCII decimal value and 0 (the first decimal number) starts at 48
     String webpage = "<h1>Hello</h1>&lth2>World!</h2><button>LED1</button>";
     String cipSend = "AT+CIPSEND=";
     cipSend += connectionId;
     cipSend += ",";
     cipSend +=webpage.length();
     cipSend +="\r\n";
     sendData(cipSend,1000);
     sendData(webpage,1000);
     webpage="<button>LED2</button>";
     cipSend += ",";
     cipSend +="\r\n";
     String closeCommand = "AT+CIPCLOSE=";
     closeCommand+=connectionId; // append connection id
     closeCommand+="\r\n";
     sendData(closeCommand,3000);
    if(triedTime<=2)
      createServer();
      triedTime +=1;
String sendData(String command, const int timeout)
    String response = "";
    ESP8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(ESP8266.available())
        // The esp has data so display its output to the serial window
        char c = ESP8266.read(); // read the next character.
        response+=c;
    Serial.print(response);
    return response;
and here is board options:
everything seems ok, i can connect to this device via android phone.
I just have one question, how can I get this device Local IP?
when I use this code to print local IP:
Serial.print("IP address: ");
it gives me this error:
'WiFi' was not declared in this scope
when I include this code:
#include <ESP8266WiFi.h>
Error compiling for board Arduino/Genuino Uno.
I don’t know how can I get this ip.
ramtinak:
Why don't you just use the Arduino ESP8266 core and write the code write totally on the ESP? It's a more powerful processor with more RAM and you don't have to mess around with AT commands or SoftwareSerial.
gfvalvo:
Why don’t you just use the Arduino ESP8266 core and write the code write totally on the ESP? It’s a more powerful processor with more RAM and you don’t have to mess around with AT commands or SoftwareSerial.
Because I don’t have that one!
ramtinak:
Because I don't have that one!
Instructions for in stalling the ESP8266 core into Arduino IDE:
@gfvalvo
Esp and arduino with at commands is working perfectly fine. No hangups or restart 2 months so far.
My system:
Main unit with 4 child units all on arduino uno with esp8266-01 as wifi shield.
@surepic
can you help me please?
surepic:
@gfvalvo
I’m sure it is. I just don’t understand why someone would want to write their main application code on an 8-bit, 16MHz, 2KB machine and then use a 32-bit, 80 MHz, 80KB machine with built-in TCP/IP Stack as only a peripheral connected by buggy SoftwareSerial.
Be that as it may, look at the WiFiESP library.
gfvalvo:
I agree
