I modified the code to fill the screen red and blue when the button is hit and also to show the RAW touch data from the screen but when the screen fills it just covers everything on the screen. how do I show different pages????
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_FT6206.h>
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 ts = Adafruit_FT6206();
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
boolean RecordOn = false;
#define FRAME_X 210
#define FRAME_Y 180
#define FRAME_W 100
#define FRAME_H 50
#define REDBUTTON_X FRAME_X
#define REDBUTTON_Y FRAME_Y
#define REDBUTTON_W (FRAME_W/2)
#define REDBUTTON_H FRAME_H
#define GREENBUTTON_X (REDBUTTON_X + REDBUTTON_W)
#define GREENBUTTON_Y FRAME_Y
#define GREENBUTTON_W (FRAME_W/2)
#define GREENBUTTON_H FRAME_H
void drawFrame()
tft.drawRect(FRAME_X, FRAME_Y, FRAME_W, FRAME_H, ILI9341_BLACK);
void redBtn()
tft.fillRect(REDBUTTON_X, REDBUTTON_Y, REDBUTTON_W, REDBUTTON_H, ILI9341_RED);
tft.fillRect(GREENBUTTON_X, GREENBUTTON_Y, GREENBUTTON_W, GREENBUTTON_H, ILI9341_BLUE);
drawFrame();
tft.setCursor(GREENBUTTON_X + 6 , GREENBUTTON_Y + (GREENBUTTON_H/2));
tft.setTextColor(ILI9341_WHITE);
tft.setTextSize(2);
tft.println("ON");
RecordOn = false;
tft.fillScreen(ILI9341_RED);
// digitalWrite(30, HIGH); //pin control
void greenBtn()
tft.fillRect(GREENBUTTON_X, GREENBUTTON_Y, GREENBUTTON_W, GREENBUTTON_H, ILI9341_GREEN);
tft.fillRect(REDBUTTON_X, REDBUTTON_Y, REDBUTTON_W, REDBUTTON_H, ILI9341_BLUE);
drawFrame();
tft.setCursor(REDBUTTON_X + 6 , REDBUTTON_Y + (REDBUTTON_H/2));
tft.setTextSize(2);
tft.println("OFF");
RecordOn = true;
tft.fillScreen(ILI9341_BLUE);
// digitalWrite(30, LOW); //pin control
void setup(void)
tft.begin();
if (!ts.begin(40)) {
Serial.println("Unable to start touchscreen.");
else {
Serial.println("Touchscreen started.");
tft.fillScreen(ILI9341_BLACK);
// origin = left,top landscape (USB left upper)
tft.setRotation(1);
redBtn();
// See if there's any touch data for us
if (ts.touched())
// Retrieve a point
TS_Point p = ts.getPoint();
// rotate coordinate system
// flip it around to match the screen.
p.x = map(p.x, 0, 240, 240, 0);
p.y = map(p.y, 0, 320, 320, 0);
int y = tft.height() - p.x;
int x = p.y;
// Print out raw data from screen touch controller
Serial.print("X = "); Serial.print(p.x);
Serial.print("\tY = "); Serial.print(p.y);
Serial.print(" -> ");
// Print out the remapped (rotated) coordinates
Serial.print("("); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.println(")");
if (RecordOn)
if((x > REDBUTTON_X) && (x < (REDBUTTON_X + REDBUTTON_W))) {
if ((y > REDBUTTON_Y) && (y <= (REDBUTTON_Y + REDBUTTON_H))) {
Serial.println("Red btn hit");
redBtn();
else //Record is off (RecordOn == false)
if((x > GREENBUTTON_X) && (x < (GREENBUTTON_X + GREENBUTTON_W))) {
if ((y > GREENBUTTON_Y) && (y <= (GREENBUTTON_Y + GREENBUTTON_H))) {
Serial.println("Green btn hit");
greenBtn();
Serial.println(RecordOn);
