creating a check password
hei guys im trying to create a check with a password and everytime at the end of the project it repeats the serial print () thats the coding plz check if there are some problems on it and thank u for ur help…
#include <Keypad.h>
int count =0;
char a[5]={‘1’,‘2’,‘3’,‘4’,‘B’};
char b[5];
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{‘1’,‘2’,‘3’,‘A’},
{‘4’,‘5’,‘6’,‘B’},
{‘7’,‘8’,‘9’,‘c’},
{’*’,‘0’,’#’,‘D’}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A5,A4, A3, A2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
Serial.println("plz enter the password and press B: ");
void loop(){
char c =keypad.getKey();
if (c !=0){
Serial.println(c);
b[count]={c} ;
count++;
if (count ==6){
for (int j=0;j<6;j++){
if (b[j]==a[j] && b[4]==‘B’){
Serial.println("welcome Home ");
else {
Serial.println(“wrong Pass”);
Maybe revise the checks a bit (not tested):
    bool
        bPass;
    char c = keypad.getKey();
    if( c != 0 )
        Serial.println(c);
        b[count] = c ;
        count++;
    }//if
    if( count == 5 )    //6 or 5?
        bPass = false;
        if( b[4] == 'B' )
            bPass = true;
            for( int j=0; j<5; j++ )   //6 or 5?
                if ( b[j] != a[j] )
                    bPass = false;
        }//if
        if( bPass )
            Serial.println("wrong Pass");
    }//if
}//loop
36mehdi:
hei guys im trying to create a check with a password and everytime at the end of the project it repeats the serial print () thats the coding plz check if there are some problems on it and thank u for ur help..
1. Let us correct/adjust your above quote first to extract some meaning out-of-it and then ask you questions.
Hey guys! I am trying to create a check with a password. The password is this: 1234 which I will enter from a Keypad. The password will be accepted only when B is entered from the Keypad and the message "Welcome Home" will appear on the Serial Monitor. But, the program is not working in my UNO setup. I have given below my codes without code tags (</>); please, help me. Thanks...!
2. What are your inputs from the Keypad/Serial Monitor to the program; what output do you expect to see on the Serial Monitor?
The answers are there in Step-1.
3. If you would use code tags (</>) with literate formatting (opening ({) and closing brace (}) should be aligned vertically), your codes would appear as shown below which is good to read and easier to debug (find software faults).
#include <Keypad.h>
int count = 0;
char a[5] = {'1', '2', '3', '4', 'B'};
char b[5];
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'c'},
  {'*', '0', '#', 'D'}
byte colPins[COLS] = {A5, A4, A3, A2}; //connect to the column pinouts of the keypad
  if (c != 0)
    Serial.println(c);
    b[count] = {c} ;
    count++;
  if (count == 6)
    for (int j = 0; j < 6; j++)
      if (b[j] == a[j] && b[4] == 'B')
4. Please, go through the slight changes I have done in your program; upload the program and check that the program outputs the expected result.
#include <Keypad.h>
int count = 0;
char b[5] = "";
bool flag1 = true;
byte rowPins[ROWS] = {2, 3, 4, 5}; //R1R2R3R4connect to the row pinouts of the keypad
byte colPins[COLS] = {A5, A4, A3, A2}; //C1C2C3C4connect to the column pinouts of the keypad
Keypad mykeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  char c = mykeypad.getKey();
  if (c != 0)
    Serial.println(c);
    b[count] = c;//{c} ;
    count++;
    if (count == 5)
      // Serial.println(b);
      // Serial.println(a);
      for (int i = 0; i < 5; i++)
        if (a[i] == b[i])
          flag1 = false;
      if (flag1 == true)
        count = 0;
        count = 0;
