Creating a chr array from an integer array
I read char string[] = {"-1200,2000,3300,-4150,5150,6000"}; from an SD card. Then I parse each element and store them into an integer array. I do some calculations with the integers and update my integer array.
Now I need to convert all the elements from my integer array to a char array to save it on the SD card.
What's the best way to do that ?
sprintf.
Or individual prints.
Define "best"
Ok, I've gotten so far:
int nums[3] { -150, -120, -170};
String string[] = {"-110,-123,-177"};
byte n;
byte s = 0;
String myString;
int myInt;
char buffer[5];
  int sizeString = (sizeof(string));
  for (n = 0; n < 3; n++) {
    myInt = nums[n];
    sprintf(buffer, "%d", myInt); /*convert int to a string and store inside a buffer*/
    myString = String(buffer);
    Serial.print("Integer Converted to String: ");
    Serial.println(myString);   /*Print string value on serial monitor*/
But now I don't know how to replace the old strings with the new strings (numbers) into my string array.
Appreciate your help
there's a difference between a String and a c-string (char array).
could be as simple as this
output:
-150,-120,-170
char buffer [80];
    sprintf (buffer, "%d,%d,%d", nums [0], nums [1], nums [2]);
    Serial.println (buffer);
Hello
Here is an example t1137640 - Wokwi ESP32, STM32, Arduino Simulator (fixed a small mistake, oops)
Thank you guix, appreciate it
Do not use char arrays at all, save the integers as integers
int nums[3] = {-2200, 1234, 4533};
File myFile;
myFile = SD.open("test.dat", FILE_WRITE);
if (myFile) {
   int myInt = nums[n];
   myFile.write(myInt, sizeof(int));
 myFile.close();
 Serial.println("done.");
Thank you. That was my original intention but I didn't know how to implement it.
@b707 , How do you read back the integer array from the SD card ?
It does not compile. Error this line:
no matching function for call to 'write(int&, unsigned int)
Please show the link to the SD library you using
#include <SPI.h>
#include <SD.h>
I think your code writes binary numbers, not integers. Without any separator, like maybe a "," , it will be impossible to read it back ?!?
Please change the line this way:
yes, it writes integers as binary data. Any data types - ints. longs, chars.... are represented as binary inside the controller.
You don't need a separator when storing/reading binary data, because the data has fixed size. Therefore, to read 3 ints you need to read 3 times of int data size bytes:
myFile.read((uint8_t*) &myInt, sizeof(int));
Here's the code I tried. It compiles and loads, but won't print anything on the serial monitor. Missing something ? Thanks.
#include <SPI.h>
#include <SD.h>
File myFile;
int n;
int myInt;
SD.remove("example.dat");
myFile = SD.open("example.dat", FILE_WRITE);
if (myFile) {
    myInt = nums[n];
   myFile.write((uint8_t*) &myInt, sizeof(int));
  myFile.close();
myFile = SD.open("example.dat", FILE_READ);
while (myFile.available()) {
      Serial.println(myFile.read((uint8_t*) &myInt, sizeof(int)));
myFile.close();
What you tried to print is return byte of the Fire.read() command, but not a myInt value.
Try this:
Sorry, still no data on the serial monitor. I checked the SD card, it's ok.
I tried an example from SD library, works fine.
I looked at the SD card on PC, There's no "example.dat" file on the card.
You did something incorrectly. Double check your code and setup.
This code works for me:
#include <SPI.h>
#include <SD.h>
  Serial.print("Initializing SD card...");
  if (!SD.begin(PA8)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  File myFile;
  int nums[3] = { -2200, 1234, 4533};
  int myInt;
  // Writing
  Serial.print("Writing to file... ");
  if (myFile) {
    for (byte n = 0; n < 3; n++) {
      myInt = nums[n];
      Serial.print(myInt);
      Serial.print(" ");
    myFile.close();
    Serial.println(" writing done.");
  // Reading
  Serial.print("Reading from file... ");
  if (myFile.available()) {
      Serial.print(" ");
  Serial.println(" reading done.");
  myFile.close();
  // nothing happens after setup
output on Serial:
Initializing SD card...initialization done.
Writing to file... -2200 1234 4533  writing done.
Reading from file... -2200 1234 4533  reading done.
Great ! It works fine. Thank you very much.
This is the "best" solution, without writing text files, parsing, transforming text to integer, etc. . Kudos.
