Creating a display from ws2801 pixels
Hey everyone! I'm new both to the forms and to arduino, though I have some background in java and pure data. I was wondering if there's any way I can make a large LED matrix work as a display... the matrix is made with (basically) these: http://www.adafruit.com/products/683 they use the ws2801, and right now, I have them built in a large matrix (it looks really cool actually) I'm just using the tester code, but I wanted to know if there was any way I could make this into a video display? Further, is there any way I could display a graphic eq on this board? to give you an idea, the board looks something like this: http://www.instructables.com/id/PixelLux-A-64-Pixel-RGB-LED-Video-Screen/ I got the physical construction stuff down cold, I'm just having a bit of difficulty programming it :P.
Thanks for your help :)
Sure, if the chips are all wired sequentially one after the other, then you blast out your data, and 500uS (confirm with the data sheet) after you stop sending data they update their outputs.
Thanks! I actually found a nifty tutorial that I've tried out...
I didn't realize, however, that my RGB pixels are actually GRB pixels... that is, sending a color value of (255, 0, 0) outputs green, (0, 255, 0) outputs red, (0, 0, 255) outputs blue, etc. instead of red, green, blue (respectively).
Since i'm using a tutorial (http://ladyada.net/make/adavision/) is there any way to change the R and G calls in the WS2801 processing library? and if so... how?
Looks like that's common: https://github.com/adafruit/Adafruit-WS2801-Library/blob/master/Adafruit_WS2801.h Guess you would change 0 t0 1 and 1 to 0 below.
// Not all LED pixels are RGB order; 36mm type expects GRB data. // Optional flag to constructors indicates data order (default if // unspecified is RGB). As long as setPixelColor/getPixelColor are // used, other code can always treat 'packed' colors as RGB; the // library will handle any required translation internally.
define WS2801_RGB 0
define WS2801_GRB 1
I don’t think editing this library will help… Because I don’t see any implementation of it in the Adavision Code…
it seems like nothing in here would do that?
// Arduino "bridge" code between host computer and WS2801-based digital
// RGB LED pixels (e.g. Adafruit product ID #322).  Intended for use
// with USB-native boards such as Teensy or Adafruit 32u4 Breakout;
// works on normal serial Arduinos, but throughput is severely limited.
// LED data is streamed, not buffered, making this suitable for larger
// installations (e.g. video wall, etc.) than could otherwise be held
// in the Arduino's limited RAM.
// Some effort is put into avoiding buffer underruns (where the output
// side becomes starved of data).  The WS2801 latch protocol, being
// delay-based, could be inadvertently triggered if the USB bus or CPU
// is swamped with other tasks.  This code buffers incoming serial data
// and introduces intentional pauses if there's a threat of the buffer
// draining prematurely.  The cost of this complexity is somewhat
// reduced throughput, the gain is that most visual glitches are
// avoided (though ultimately a function of the load on the USB bus and
// host CPU, and out of our control).
// LED data and clock lines are connected to the Arduino's SPI output.
// On traditional Arduino boards, SPI data out is digital pin 11 and
// clock is digital pin 13.  On both Teensy and the 32u4 Breakout,
// data out is pin B2, clock is B1.  LEDs should be externally
// powered -- trying to run any more than just a few off the Arduino's
// 5V line is generally a Bad Idea.  LED ground should also be
// connected to Arduino ground.
#include <SPI.h>
// LED pin for Adafruit 32u4 Breakout Board:
//#define LED_DDR  DDRE
//#define LED_PORT PORTE
//#define LED_PIN  _BV(PORTE6)
// LED pin for Teensy:
#define LED_DDR  DDRD
#define LED_PORT PORTD
#define LED_PIN  _BV(PORTD6)
// LED pin for Arduino:
//#define LED_DDR  DDRB
//#define LED_PORT PORTB
//#define LED_PIN  _BV(PORTB5)
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch).  You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives.  The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55).  LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {'A','d','a'};
#define MAGICSIZE  sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_HOLD   1
#define MODE_DATA   2
// If no serial data is received for a while, the LEDs are shut off
// automatically.  This avoids the annoying "stuck pixel" look when
// quitting LED display programs on the host computer.
static const unsigned long serialTimeout = 15000; // 15 seconds
  // Dirty trick: the circular buffer for serial data is 256 bytes,
  // and the "in" and "out" indices are unsigned 8-bit types -- this
  // much simplifies the cases where in/out need to "wrap around" the
  // beginning/end of the buffer.  Otherwise there'd be a ton of bit-
  // masking and/or conditional code every time one of these indices
  // needs to change, slowing things down tremendously.
  uint8_t
    buffer[256],
    indexIn       = 0,
    indexOut      = 0,
    mode          = MODE_HEADER,
    hi, lo, chk, i, spiFlag;
  int16_t
    bytesBuffered = 0,
    hold          = 0,
    c;
  int32_t
    bytesRemaining;
  unsigned long
    startTime,
    lastByteTime,
    lastAckTime,
    t;
  LED_DDR  |=  LED_PIN; // Enable output for LED
  LED_PORT &= ~LED_PIN; // LED off
  Serial.begin(115200); // Teensy/32u4 disregards baud rate; is OK!
  SPI.begin();
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE0);
  SPI.setClockDivider(SPI_CLOCK_DIV16); // 1 MHz max, else flicker
  // Issue test pattern to LEDs on startup.  This helps verify that
  // wiring between the Arduino and LEDs is correct.  Not knowing the
  // actual number of LEDs connected, this sets all of them (well, up
  // to the first 25,000, so as not to be TOO time consuming) to red,
  // green, blue, then off.  Once you're confident everything is working
  // end-to-end, it's OK to comment this out and reprogram the Arduino.
  //mine flashes G, R, B
  uint8_t testcolor[] = { 0, 0, 0, 255, 0, 0 };
  for(char n=3; n>=0; n--) {
    for(c=0; c<25000; c++) {
      for(i=0; i<3; i++) {
        for(SPDR = testcolor[n + i]; !(SPSR & _BV(SPIF)); );
    delay(1); // One millisecond pause = latch
  Serial.print("Ada\n"); // Send ACK string to host
  startTime    = micros();
  lastByteTime = lastAckTime = millis();
  // loop() is avoided as even that small bit of function overhead
  // has a measurable impact on this code's overall throughput.
  for(;;) {
    // Implementation is a simple finite-state machine.
    // Regardless of mode, check for serial input each time:
    t = millis();
    if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
      buffer[indexIn++] = c;
      bytesBuffered++;
      lastByteTime = lastAckTime = t; // Reset timeout counters
      // No data received.  If this persists, send an ACK packet
      // to host once every second to alert it to our presence.
      if((t - lastAckTime) > 1000) {
        lastAckTime = t; // Reset counter
      // If no data received for an extended time, turn off all LEDs.
      if((t - lastByteTime) > serialTimeout) {
        for(c=0; c<32767; c++) {
          for(SPDR=0; !(SPSR & _BV(SPIF)); );
        lastByteTime = t; // Reset counter
    switch(mode) {
     case MODE_HEADER:
      // In header-seeking mode.  Is there enough data to check?
      if(bytesBuffered >= HEADERSIZE) {
        // Indeed.  Check for a 'magic word' match.
        for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
        if(i == MAGICSIZE) {
          // Magic word matches.  Now how about the checksum?
          hi  = buffer[indexOut++];
          lo  = buffer[indexOut++];
          chk = buffer[indexOut++];
          if(chk == (hi ^ lo ^ 0x55)) {
            // Checksum looks valid.  Get 16-bit LED count, add 1
            // (# LEDs is always > 0) and multiply by 3 for R,G,B.
            bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
            bytesBuffered -= 3;
            spiFlag        = 0;         // No data out yet
            mode           = MODE_HOLD; // Proceed to latch wait mode
            // Checksum didn't match; search resumes after magic word.
            indexOut  -= 3; // Rewind
        } // else no header match.  Resume at first mismatched byte.
        bytesBuffered -= i;
     case MODE_HOLD:
      // Ostensibly "waiting for the latch from the prior frame
      // to complete" mode, but may also revert to this mode when
      // underrun prevention necessitates a delay.
      if((micros() - startTime) < hold) break; // Still holding; keep buffering
      // Latch/delay complete.  Advance to data-issuing mode...
      mode      = MODE_DATA; // ...and fall through (no break):
     case MODE_DATA:
      while(spiFlag && !(SPSR & _BV(SPIF))); // Wait for prior byte
      if(bytesRemaining > 0) {
        if(bytesBuffered > 0) {
          SPDR = buffer[indexOut++];   // Issue next byte
          bytesBuffered--;
          bytesRemaining--;
          spiFlag = 1;
        // If serial buffer is threatening to underrun, start
        // introducing progressively longer pauses to allow more
        // data to arrive (up to a point).
        if((bytesBuffered < 32) && (bytesRemaining > bytesBuffered)) {
          hold      = 100 + (32 - bytesBuffered) * 10;
          mode      = MODE_HOLD;
        // End of data -- issue latch:
        hold       = 1000;        // Latch duration = 1000 uS
        LED_PORT  |= LED_PIN;     // LED on
        mode       = MODE_HEADER; // Begin next header search
    } // end switch
  } // end for(;;)
  // Not used.  See note in setup() function.
Have you tried FastSPI (http://code.google.com/p/fastspi/)? It has the option of switching RGB to GRB ... And it uses SPI to update the string. Something else you may want to consider is to use WS2803 chips instead of WS2801s. The -03 has 18 channels of output (for 6 RGB LEDs) versus the 3 (for 1 RGB LED) on the -01.
I've used both, and built several lengths of string with both of them.
