Hello again. I have made a post before about the solenoid for my project but as I am working on one side my group helps with another. We have learned how to program a TMP36 Temp. Sensor to the LCD display. And after learning that one (waiting for the actual part to arrive), we finally got to try the temperature sensor waterproof. We just replaced the air sensor with the water one.
Here is the code we were following:
We just replaced the TMP36 sensor and made this:
My advice is to read and follow the instructions in the "How to get the best out of this forum" post, which gives suggestions on what you need to do to get help on this forum.
If this post is a continuation of a previous project thread, please use the flag button to ask a moderator to combine the posts.
Had you read "how to get..." you would understand it is counterproductive to run parallel topics about a single project, however you might like to focus on only parts. Please request a merge. In addition, given the multiple posts on the other thread, please then post one consolidated summary of your project and it's multiple needs, so we can move forward together.
Well currently it is two different projects. Our goal is to figure them out separately but they both have the same end goal. I am new to this sort of contact with help so if I need to combine the forums I will try.
Ahh. So explanations of one job won't lead to questions about the other? In that case proceed, I suppose, but be aware that every time you explain something that references the other project, you'll face this same discussion. It's inevitable, because when we're requesting schematics, diagrams, photos, etc. we so often see elements we're 'not supposed to be aware of' that become questions unto themselves.
I did message about merging the posts and they saw that the posts are two different components. So when I get back to my project I will send out what I have so far if you all could still help please. Thank you
@lylz That's fine, but please note post #7. Information is needed to proceed; the topic is going nowhere useful without clarity; maintaining two independent topics will be your burden.
