Hi to all,
For my new project I need to reconfigure the SERCOMs to get three UART and three I2C buses.
I have been following these guides:
The three UART work, however I cannot get the secondary Wire to work.
The hardware is a Sparkfun SAMD21 Mini and three BME280 sensors, connected to pins as follows, with 4k7 pullups (SDA, SCL): (A4, A5), (4, 3), (11, 13)
I carefully selected the pins out of the table in the SAMD21 datasheet, they should be correct.
The first bus is default and works, the 2nd is on SERCOM0 and the 3rd on SERCOM1.
This is the test code for a single Wire:
#include "wiring_private.h" // pinPeripheral() function
#include <Wire.h>
#include <SparkFunBME280.h>
TwoWire myWire(&sercom0, 4, 3);
BME280 bme1; // I2C
void SERCOM0_Handler(void);
void SERCOM0_Handler(void) {
myWire.onService();
SerialUSB.begin(115200);
while (!SerialUSB) {
; // wait for serial port to connect
SerialUSB.println("SAMD21 Test Initialization");
SerialUSB.println();
SerialUSB.println("Initializing I2C on pin 4, 3");
myWire.begin();
pinPeripheral(3, PIO_SERCOM);
pinPeripheral(4, PIO_SERCOM);
SerialUSB.println("Inizialized, looking for sensor");
if(bme1.beginI2C(myWire) == false) {
SerialUSB.println("Sensor NOT found!");
SerialUSB.println("Sensor found");
SerialUSB.print("Sensor 2 temp: ");
SerialUSB.println(bme1.readTempC(), 2);
delay(5000);
The sketch will be stuck at "Inizialized, looking for sensor".
Tried to do the same with Adafrult BME280 library, still stuck.
If I run the I2C scanner code, the device is correctly found at address 0x77 so at least something is clicking.
Any advice?
Thank you!
Nick
