Creating a pseudo load
I’m trying to create a pseudo load to keep an existing electronic control module happy when I switch an external input.
The electronic control usually controls a solenoid with a 5ohm resistance.
I’ve tried to switch it to a 5ohm wire wound resistor but it gets very hot very quickly.
How can I replicate the solenoid?
what wattage is the resistor rated? What voltage are you dealing with?
its a 5W resistor and a 5V circuit.
You are expecting a 5 watt resistor to dissipate its ABSOLUTE MAXIMUM amount of heat, 5 watts. Expect it to get hot!
