Creating a pulse multiplier?
I'd like to use the Arduino to create a pulse divider. My input is a 1PPS, 8us 5v pulse from a GPS that I will use for timekeeping. I'd like to use that to create a 10hz 10us 5v output pulse.
Any suggestions or example projects to look at?
Thanks!
1Hz input and 10Hz output is a pulse multiplier, not a divider. Google for "software phase locked loop".
There’s 1,000,000uS in a second.
(1,000mS in a second)
So once a second you’re like a little burst of 10uS pulses at a 10 Hz rate?
|–|________________________________________________|–|
to: High for 10uS, Low for 99,990uS, repeat 10 times, repeat with next 1PPS pulse
|—||—||—||—||—||—||—||—|_
Ok, I understand how it would be a multiplier.
CrossRoads: There's 1,000,000uS in a second. (1,000mS in a second) So once a second you're like a little burst of 10uS pulses at a 10 Hz rate?
from: High for 8uS, Low for 999,992us |--|________________________________________________________|--|__________ to: High for 10uS, Low for 99,990uS, repeat 10 times, repeat with next 1PPS pulse |---||---||---||---||---||---||---||---||---||---|___
Yes! That's what I would like to implement. I'm not sure how to do it though, because you would need to wait for a couple input pulses before performing the arithmetic though, right?
wrong, look at reply #1.
Ok, since this is my first Arduino program I have started simple in hopes of moving my way up.
What I have succeeded in doing is measuring an interval between button presses, then blinking an LED at a fraction of that interval for a certain number of times.
The problem is that while the LED blinks correctly (at a rate proportional to the interval measured), I can only get it to do it for a fixed number of times using my While loop.
I would like to modify this so that the LED blinks at a fraction of the latest interval measured, until the next button press is registered (signalling a new interval.)
#define  DELAY_START   HIGH
#define  DELAY_END   !DELAY_START
int ledPin = 3;
int inputPin = 2;
int x;
long start, duration, fduration, interval;
  pinMode(ledPin, OUTPUT);
  pinMode(inputPin, INPUT);
void loop(){
  while( digitalRead(inputPin) != DELAY_START   )
  start = millis();
  while( digitalRead(inputPin) != DELAY_END   )
  duration = start - millis();
  fduration = 0 - duration;                //for some reason my duration was negative so this makes it positive
  interval = fduration / 10;
  Serial.println(fduration);
  for(int x = 0; x < 10; x++){
  digitalWrite(ledPin, HIGH);
  delay(10);
  digitalWrite(ledPin, LOW);
  delay(interval);
Well I abandoned the attempt above because I realized that using delay() wasn't going to work as it pauses the entire program. Instead I found an example, called Blink Without Delay, and added/modified the following lines:
 outputInterval = interval / 500;
  if(currentMillis - previousMillis > outputInterval)
Since I am trying to create subintervals out of an input pulse, that was in hopes of taking the measured interval and dividing it by a constant to get a faster pulse.
However that part didn't work, the output pulse stayed precisely 2x slower than the input pulse regardless of what I changed the constant to be.
Any suggestions?
My full code:
const int ledPin =  7;      // the number of the LED pin
int ledState = LOW;             // ledState used to set the LED
int pin = 2;
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval;           // interval at which to blink (milliseconds)
long outputInterval;
pinMode(pin, INPUT);
  interval = pulseIn(pin, HIGH);
  Serial.println(interval);
  if(currentMillis - previousMillis > outputInterval) {
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(ledPin, ledState);
millis() returns unsigned long change your time variables to be unsigned long also.
You are only changing ledState one time after the end of the pulse measuring.
You need a for next loop after measuring the pulse width:
for (int i = 0; i<10; i+i+1){
//write the LED hi, lo with delay that is = to outputInterval
digitalWrite (ledPin, HIGH);
delay (outputInterval);
digitalWrite (ledPin, LOW);
That will get you to a set of pulses at the end of a pulse measurement; I think that will look like a burst of pulses during the off time of your initial pulse.
digitalWrite might slow the response down, in which case you use direct port manipulation:
// set output bit High, leave rest alone
PORTD = PIND | B10000000; // assumes ledPin is PortD, bit 7 for this example
delay(outputInterval);
// clear the output bit, leave rest alone
PORTD = PIND & B01111111;
