I am trying to create a secure access point with atwinc 1500 and I am stuck. So far I have been able to integrate the open ap arduino code with a bit of ESP8266 code. I am now able to get a secure access point however, I can't log into it. I am attaching my code below for any help I can get. Thanks in advance.
#include <SPI.h>
#include <WiFi101.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/*char ssid[] = "Maggie"; // your network SSID (name)
char pass[] = "Mindya"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;// your network key Index number (needed only for WEP)*/
const char* ssid = "Maggie";
const char* password = "Maggie";
int led = LED_BUILTIN;
int status = WL_IDLE_STATUS;
String header;
WiFiServer server(80);
WiFi.setPins(6,3,14);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Access Point Web Server");
pinMode(led, OUTPUT); // set the LED pin mode
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// by default the local IP address of will be 192.168.1.1
// you can override it with the following:
// WiFi.config(IPAddress(10, 0, 0, 1));
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid ); // When I add password here the code immediately fails
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10 seconds for connection:
delay(10000);
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
printWiFiStatus();
// compare the previous status to the current status
if (status != WiFi.status()) {
// it has changed update the variable
status = WiFi.status();
if (status == WL_AP_CONNECTED) {
byte remoteMac[6];
// a device has connected to the AP
Serial.print("Device connected to AP, MAC address: ");
WiFi.APClientMacAddress(remoteMac);
printMacAddress(remoteMac);
// a device has disconnected from the AP, and we are back in listening mode
Serial.println("Device disconnected from AP");
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c);
header +=c;
// print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
if(header.indexOf("dXNlcjpwYXNz") >= 0) {
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
client.println("<!DOCTYPE html>\n");
client.println("<html>\n");
client.println("<body>\n");
client.println("<center>\n");
client.println("<h1 style=\"color:blue;\">ESP32 webserver</h1>\n");
client.println("<h2 style=\"color:green;\">Hello World Web Sever</h2>\n");
client.println("<h2 style=\"color:blue;\">Password protected Web server</h2>\n");
client.println("</center>\n");
client.println("</body>\n");
client.println("</html>");
// Wrong user or password, so HTTP request fails...
else {
client.println("HTTP/1.1 401 Unauthorized");
client.println("WWW-Authenticate: Basic realm=\"Secure\"");
client.println("Content-Type: text/html");
client.println();
client.println("<html>Authentication failed</html>");
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
