Creating a serial number for sd card files
Hello,
I am pretty sure (since I’m generally a poor programmer) there’s a simple answer out there, but after trying to bang my way through using the typical google>copy>modify approaches, I’m stuck.
I want to create a serial number for image files I’m saving to an SD card. I want them to be in the form “IMAGE000.JPG” and be able to go up to 999. I borrowed a bit of code for 1-99 that worked just fine, but when I adapted it to what I thought would work for 1-999. I got some weird outputs. It works up to 99, but then the middle digit turns into characters. See below
I won’t include the whole program, but a simple version of this is below to see how it’s structured.
  char filename[13];
    strcpy(filename, "IMAGE000.JPG");
    for (int i = 0; i < 1000; i++) {
      filename[5] = '0' + i / 100;
      filename[6] = '0' + i / 10;
      filename[7] = '0' + i % 10;
    Serial.println(filename);
    delay(100);
At a guess (and not knowing why) it seems like the middle digit is not rolling back to 0 after 9, but going on to other characters that represent something to it.
Love to sort this out, and welcome your help
kifling: At a guess (and not knowing why) it seems like the middle digit is not rolling back to 0 after 9
Congrats, you already found your problem. Now take a closer look at your code ;) Do you understand what the line
does?
Hint: (look what comes after '9' in the "Chr" column) |500x341
lg, couka
The sprintf() function is probably overkill, but WILL solve your problem quite nicely.
   sprintf(filename, "IMAGE%03d.txt", i);
Try:
int num = i;
filename[7] = '0' + ( num % 10 );
num /= 10;
filename[6] = '0' + ( num % 10 );
num /= 10;
filename[5] = '0' + num;
or:
filename[7] = '0' + ( i % 10 );
filename[6] = '0' + ( ( i / 10 ) % 10 );
filename[5] = '0' + ( i / 100 );
