Creating a timed dimmer loop with Arduino?
https://www.google.com/search?ie=UTF-8&oe=UTF-8&q=light+dimming&btnG=search&domains=http%3A%2F%2Fwww.arduino.cc&sitesearch=http%3A%2F%2Fwww.arduino.cc%2Fcgi-bin%2Fyabb2%2F
Flourescent lights can't be dimmed all the way to dark. If you use a standard dimmer circuit, you need 'dimmable' CFL bulbs for a dimmer to work at all.
If they will work in your application, LEDs are very easy to control and the brightness can be controlled across the full range of brightness.
Good luck,
Steve
