Hi there,
I am flashing code to an ATTINY84 and have stumbled upon a problem.
On the Arduino UNO, using the Tone() function was the easiest way to do this. But analyizing the output on the ATTINY84 PWM pin (pin 8), the scope doesnt read a square wave.
My next thought was to do create a HIGH / LOW loop on pin 8 utilizing the delayMicroseconds functions but the lowest it will go do with 1 microsecond between HIGH and LOW, the scope reads 5.55 kHZ.
This frequency needs to be 25-26kHz that changes with an AnalogRead function (that I have connected to another pin using a potentiometer as a voltage divider).
Any tips? Thanks!
