creating a weather station
can anyone give me the code for program (and wiring diagram) to build a mini-weather station
I only have the ff materials:
Arduino UNO
BMP 280 sensor
128x64 OLED
8 pieces jumper wires
400 pts breadboard
Could you take a few moments to Learn How To Use The Forum.
Posting tips.
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • How to insert an image into your post. ( Thanks Robin2 )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
BMP 280 sensor
I'm sure adafruit has a library and sample code for that.
How on earth did you end up with materials like that before having a circuit diagram and maybe some example code to try? You'd better get off your arse and doing some work for yourself, start googling
Google arduino bmp280
Arduino 128x64
When you use arduino in the search you get better results
cactus.io
