I am creating XML to be read in a Java program using the XStream library through the serial port. I'm doing like the code below, but would there be any simpler way to send this XML?
#ifndef __GRAVITY_CAR_H__
#define __GRAVITY_CAR_H__
#include <SoftwareSerial.h>
#include "Arduino.h"
#define XML_BUFFER_SIZE 64
#define XML_HEADER "<?xml version=\"1.0\" encoding=\"UTF-8\"?>"
#define XML_LEFT_BRAKE_TAG "<leftBrake> "
#define XML_RIGHT_BRAKE_TAG "<rightBrake> "
#define XML_STEERING_ANGLE_TAG "<steerAngle> "
#define XML_LEFT_BRAKE_END_TAG " </leftBrake>"
#define XML_RIGHT_BRAKE_END_TAG " </rightBrake>"
#define XML_STEERING_ANGLE_END_TAG " </steerAngle>"
class GravityCar {
public:
GravityCar(int leftBrakePin, int rightBrakePin, int steeringAnglePin);
void writeSerialXml(SoftwareSerial bluetooth);
int getLeftBrake() const { return analogRead(mLeftBrakePin); }
int getRightBrake() const { return analogRead(mRightBrakePin); }
int getSteeringAngle() const { return analogRead(mSteeringAnglePin); }
private:
int mLeftBrakePin;
int mRightBrakePin;
int mSteeringAnglePin;
//StaticJsonDocument<JSON_BUFFER_SIZE> document;
#endif /* __GRAVITY_CAR_H__ */
#include "GravityCar.h"
GravityCar::GravityCar(int leftBrakePin, int rightBrakePin, int steeringAnglePin) {
pinMode(leftBrakePin, INPUT);
pinMode(rightBrakePin, INPUT);
pinMode(steeringAnglePin, INPUT);
mLeftBrakePin = leftBrakePin;
mRightBrakePin = rightBrakePin;
mSteeringAnglePin = steeringAnglePin;
void GravityCar::writeSerialXml(SoftwareSerial bluetooth) {
bluetooth.print("\n");
bluetooth.flush();
bluetooth.print(XML_HEADER);
bluetooth.print(XML_LEFT_BRAKE_TAG);
bluetooth.print(getLeftBrake());
bluetooth.print(XML_LEFT_BRAKE_END_TAG);
bluetooth.print(XML_RIGHT_BRAKE_TAG);
bluetooth.print(getRightBrake());
bluetooth.print(XML_RIGHT_BRAKE_END_TAG);
bluetooth.print(XML_STEERING_ANGLE_TAG);
bluetooth.print(getSteeringAngle());
bluetooth.print(XML_STEERING_ANGLE_END_TAG);
bluetooth.flush();
#define PIN_LEFT_BRAKE A1
#define PIN_RIGHT_BRAKE A3
#define PIN_STEERING_ANGLE A2
#define PIN_BLUETOOTH_RX 2
#define PIN_BLUETOOTH_TX 3
#define SERIAL_BAUD_RATE 9600
#define INTERVAL 10
SoftwareSerial BTSerial(PIN_BLUETOOTH_RX, PIN_BLUETOOTH_TX);
GravityCar car(PIN_LEFT_BRAKE, PIN_RIGHT_BRAKE, PIN_STEERING_ANGLE);
long previousMillis = 0;
Serial.begin(SERIAL_BAUD_RATE);
BTSerial.begin(SERIAL_BAUD_RATE);
car.writeSerialXml(BTSerial);
delayMicroseconds(INTERVAL);
