Creating/Accessing data on MKR MEM
So recently I have been trying to create a file using the PaulStoffregen SerialFlash but could never succeed for some reason.
#include <SPI.h>
#include <Arduino_MKRGPS.h>
#include <SerialFlash.h>
const int FlashChipSelect = 5;
const char *filename = DATA.TXT;
uint32_t length = 1999000;
  while (!Serial) {
  GPS.begin();
  if (!SerialFlash.begin(FlashChipSelect)) {
    error("Unable to access SPI Flash chip");
  } Serial.println("Connection successful");
SerialFlash.createErasable(filename, length);
GPS.wakeup();
retry:
  if (GPS.available())
     float latitude   = GPS.latitude();
     float longitude  = GPS.longitude();
     float altitude   = GPS.altitude();
     float speed      = GPS.speed();
     float satellites   = GPS.satellites();
     float course       = GPS.course();
void error(const char *message) {
  while (1) {
    Serial.println(message);
    delay(2500);
This is my code and when I run it I get this error
C:\Users\user\OneDrive\Documents\Arduino\sketch_sep9a\sketch_sep9a.ino:5:24: error: 'DATA' was not declared in this scope
C:\Users\user\OneDrive\Documents\Arduino\sketch_sep9a\sketch_sep9a.ino:5:24: note: suggested alternative: 'DAC'
                        DAC
exit status 1
Compilation error: 'DATA' was not declared in this scope
On GitHub there is very little information on creating the files or how to approach any errors that may occur.
I'm very confused as to why DATA is not declared and have no idea how to fix it, any help is very appreciated.
Maybe try:
const char *filename = "DATA.TXT";
EDIT: The library mentioned below also includes some examples. Have a look as they are usually a good starting point for your own project.
Yeah, I did notice it, but all that it says it the command
:man_shrugging:
EDIT: it worked. I can't believe I didn't think of this. Thanks again
