Hello everyone,
I've been working with Arduino for a little over a month now, and I'm currently trying to create a gaming controller. However, I'm new to coding and could use some help figuring out how to send commands from buttons and a joystick to an Android app named Toca Boca APK.
Here's a sketch of what I've done so far:
#include <HC05.h>
#include <maker_joystick.h>
#include <Pushbutton.h>
int PushbuttonA = 8;
int PushbuttonB = 9;
int PushbuttonC = 10;
int PushbuttonD = 11;
int maker_joystick = 2;
int HC05 = 1;
const int inPressed = 2;
const int inX = A0; // analog input for x-axis
const int inY = A1; // analog input for y-axis
int xValue = 0;
int yValue = 0;
int buttonStateA = LOW;
int buttonStateB = LOW;
int buttonStateC = LOW;
int buttonStateD = LOW;
int connected = 1;
pinMode(PushbuttonA, INPUT);
pinMode(PushbuttonB, INPUT);
pinMode(PushbuttonC, INPUT);
pinMode(PushbuttonD, INPUT);
pinMode(maker_joystick, INPUT);
pinMode(HC05, OUTPUT);
digitalWrite(HC05, HIGH);
pinMode(inPressed, INPUT);
// Read button states
buttonStateA = digitalRead(PushbuttonA);
buttonStateB = digitalRead(PushbuttonB);
buttonStateC = digitalRead(PushbuttonC);
buttonStateD = digitalRead(PushbuttonD);
// Handle button presses
if (buttonStateA == HIGH) {
// Send command to shoot
// Example: sendCommand("shoot");
if (buttonStateB == HIGH) {
// Send command to use scope
// Example: sendCommand("scope");
if (buttonStateC == HIGH) {
// Send command to crouch
// Example: sendCommand("crouch");
if (buttonStateD == HIGH) {
// Send command to jump
// Example: sendCommand("jump");
// Read joystick values
xValue = analogRead(inX);
yValue = analogRead(inY);
// Map joystick values to actions (if needed)
// Example: mapJoystickToActions(xValue, yValue);
delay(100); // Adjust delay as needed
// Function to send commands to Toca Boca APK
void sendCommand(String command) {
// Implement code to send commands via Bluetooth or other communication protocol
// Function to map joystick values to actions
void mapJoystickToActions(int x, int y) {
// Implement mapping logic based on joystick readings
I'm particularly struggling with how to effectively send commands from the buttons (A, B, C, D) and the joystick (X and Y axis) to control actions in the Toca Boca APK. Any guidance or suggestions on how to improve my code would be greatly appreciated!
Looking forward to your insights. Thanks!
