Creating an ECG signal
Hey there!!
I'm trying to create an ECG signal using arduino but I pretty new at this. I'm supposed to recreate a signal or voltage that's gonna be recieved by an actual ECG and it's going to have certain parameters which I'm gonna set myself but the question is, how do I send that voltage or data to the arduino? How can I program it?
Thanks for reading :slightly_smiling_face:
Your post was MOVED to it's current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Well, you do not send a voltage to the Arduino if you want it to synthesise an ECG wave form.
Generally you make a numerical record of the waveform you wish to generate and store that record in the Arduino either in program memory, the EEPROM or a SD card in an adapter, and the Arduino successively reads out those data points to a PWM pin with a low-pass filter to smooth the PWM output.
And of course you program the Arduino with the Arduino IDE.
Welcome to the forum.
Can you please tell us your electronics, programming, arduino, hardware experience?
Is this a school/college/university project/practical?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Thank you so much Paul!
I'm currently working on everything you said! Lately I've been thinking about using the PWM to generate the ECG wave but didn't know how to work it out. Now I have some kind of guidance thanks to you!!
