Hi all,
I am playing around with some capacitive moisture sensors that output an analog value using an ESP32 with the Arduino IDE.
My goal is to have about 7 sensors in my new vegetable garden and output those readings to a very basic webpage.
I figured since I will be using 7 of them, it would be a good idea to write a class for them to keep the code a bit tidier.
What I have done (successfully) so far:
Constructor
Getter for pin number
Setter for reading raw ADC values into object
Getter for getting raw ADC values from object
Now I am trying to use the digitalSmooth library Arduino Playground - DigitalSmooth
I have successfully tested the library in a basic sketch before I started writing this class.
However now when I call the digitalSmooth method from within my setup(), instead of returning a value that makes sense,I get a core panic.
Here is the output (over and over as it keeps rebooting):
34
3391
In digitalSmooth: 3391
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d0c20 PS : 0x00060930 A0 : 0x800d0cfa A1 : 0x3ffb1f60
A2 : 0x3ffc0194 A3 : 0x00000d3f A4 : 0x00000000 A5 : 0x3ffc0490
A6 : 0x00000001 A7 : 0x00000000 A8 : 0x00000004 A9 : 0x3ffc00bc
A10 : 0x00000000 A11 : 0x3ffc0188 A12 : 0x0000000a A13 : 0x3ffb1e60
A14 : ⸮⸮
So I can see it prints out all of the stuff before digitalSmooth. I havent ever seen a core panic before, so I’m a bit lost. I’m pretty sure the problem may have something to do with the the variable sensSmoothArray being passed to the method, but I’m not great with pointers.
I noticed in the example from the link above, when they call the method they don’t need to use the dereference operator, however in order to get it to compile I had to add it.
Can anyone please suggest what I am doing wrong?
Here is my code:
* MoistureSensor.h
* Library for usng multiple Capacitive Moisture Sensors
#ifndef MoistureSensor_h
#define MoistureSensor_h
#include "Arduino.h"
#define filterSamples 51 // filterSamples should be an odd number, no smaller than 3
class MoistureSensor
private:
int _pin;
int rawData; // raw ADC values
int smoothData; // variables for sensor data
public:
MoistureSensor(int pin); // constructor
int *sensSmoothArray [filterSamples]; // array for holding raw sensor values for sensor1
int getPin(void); // get pin number for a given sensor
int digitalSmooth(int, int*);
void setRawData(void); // setter for result of ADC read
int getRawData(void); // getter for result of ADC read
#endif
* MoistureSensor.cpp
#include "MoistureSensor.h"
MoistureSensor::MoistureSensor(int pin)
_pin = pin;
int MoistureSensor::getPin(void)
return _pin;
void MoistureSensor::setRawData()
rawData = analogRead(_pin);
int MoistureSensor::getRawData(void)
return rawData;
int MoistureSensor::digitalSmooth(int rawIn, int *sensSmoothArray)
Serial.print("In digitalSmooth: "); Serial.println(rawIn);
int j, k, temp, top, bottom;
long total;
static int i;
// static int raw[filterSamples];
static int sorted[filterSamples];
boolean done;
i = (i + 1) % filterSamples; // increment counter and roll over if necc. - % (modulo operator) rolls over variable
sensSmoothArray[i] = rawIn; // input new data into the oldest slot
// Serial.print("raw = ");
for (j = 0; j < filterSamples; j++) { // transfer data array into anther array for sorting and averaging
sorted[j] = sensSmoothArray[j];
done = 0; // flag to know when we're done sorting
while (done != 1) { // simple swap sort, sorts numbers from lowest to highest
done = 1;
for (j = 0; j < (filterSamples - 1); j++) {
if (sorted[j] > sorted[j + 1]) { // numbers are out of order - swap
temp = sorted[j + 1];
sorted [j + 1] = sorted[j] ;
sorted [j] = temp;
done = 0;
for (j = 0; j < (filterSamples); j++){ // print the array to debug
Serial.print(sorted[j]);
Serial.print(" ");
// throw out top and bottom 15% of samples - limit to throw out at least one from top and bottom
bottom = max(((filterSamples * 15) / 100), 1);
top = min((((filterSamples * 85) / 100) + 1 ), (filterSamples - 1)); // the + 1 is to make up for asymmetry caused by integer rounding
k = 0;
total = 0;
for ( j = bottom; j < top; j++) {
total += sorted[j]; // total remaining indices
k++;
// Serial.print(sorted[j]);
// Serial.print(" ");
// Serial.println();
// Serial.print("average = ");
// Serial.println(total/k);
smoothData = total / k;
Serial.print("Smooth Data Variable: "); Serial.println(smoothData);
//Serial.print("\n\nDigitalSmooth Reading: "); Serial.println(MoistureSensor::getSmoothData());
return total / k; // divide by number of samples
MoistureSensor sensor1(34);
Serial.println(sensor1.getPin());
sensor1.setRawData();
int raw = sensor1.getRawData();
Serial.println(raw);
int smoothed = sensor1.digitalSmooth(raw, *sensor1.sensSmoothArray);
//Serial.println(smoothed);
