Creating enhanced solution for bicycle-based warning system
I was wondering if this can be achieved.
It might be if you could actually explain what you meant.
@idrab
Please read this:
In case of a calamity, carry this and then cycle around town:
Okay, thanks for your quick response. I meant to create a system that uses improved haptic cues for cyclist safety in the Cooperative - V2X (Vehicle-to-Everything) system because research shows that using visuals can distract cyclists. In addition, while the literature had worked on using Lidars, I thought that the issue being reported i.e, the range limit of 40m can be extended for the proper field of view. if so, how do we go about it in terms of getting sensors needed and implementation? Ref: IEEE Xplore Full-Text PDF:
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
I have no idea what you are trying to do . You need to be more specific about what you want to do - what sensors , measuring what , to perform what function and what output .
From what I can make out, your idea looks pretty complex , maybe too complex .
What haptic cues, and how will they be improved?
